Thanks Rusty for this site link
http://www.dansmc.com/torque_chart.htmits saved me a bundle with Suzuki bits I needed as Suzi charge more than a wounded elephant for the same items.
My Uncles solution pretty much solved all issues with flywheel bolts from A to Z series.
For the A I followed his advise after researching the qualities of Loctite 266 and to mark with chalk the old bolts and then torque them back on the flywheel leaving space for one of the new ones each time, this prevents the Loctite getting in between the flywheel and crank which can prevent proper torque readings.
For extra strength I noticed that only the A10 comes with 3 black carbon steel secure locking tabs for each pair of flywheel bolts to stop them coming loose (I havent noticed this for A12/14/15 I played with as never got a virgin one) yet used the same tabs on them in most cases.
These tabs with the Loctite 266 at 10psi higher than the recommended 65psi from factory has been very effective even with an idiot who bought one of my old B10s and revved it like a motorbike as he wanted to blow it up by taking it to 10k rpm all the time. Eventually a valve hit the pistons and it chewed itself up but flywheel bolts where still hard to remove until I heated them up a tad.
Never overtighten the factory rod bolts as you will get unlucky as they do stretch as Rusty has stated.
If possible clean up your flywheel and crank surface contact area really well so it has nothing but clean steel! if time permits spend a little time and money to get the flywheel rebalanced to make sure your rebuild gets the best possible chance of lasting for years of abuse :)
