Several have mentioned problems shifting at RPMs above 5000. 2nd gear wasn't mentioned.
Now of course this wasn't a problem with a new box as they were fitted to engines with a 7000 RPM redline. And not specific to the stumpy, but to all 71B series (280ZX, etc). The newer 71C has improvements. The 71B took more time to shift (needed more time to synchronize)
dattodude: The Stumpy gearbox that I had, wouldn't shift at over 5000 revs. So I had to crunch it into gear when drag racing.
So apparently it did shift, but "crunched", which sounds like a synchro problem.
General factors affecting syncros:
* Incorrect gearbox fluid. Using 10W40 not recommended. Using ATF not recommended. Synchro depends on friction, so use the recommended 75-140 weight oil
* Worn synchros
* Corroded synchros. Using GL-5 lube can do this. Use the recommend GL-4 "safe for yellow brass" oil
