r31 skyline diff
From Kelmscott Western Australia
Gday all
i pick up a r31 skyline diff and im thinking to put into my ute
my question is who here has done it and what is involved in shorting the axle caseing
how much does it need to be cut
cheers
Posted on: 2016/2/24 11:06
Re: r31 skyline diff
Quite a regular
Posted on: 2016/2/24 11:26
It is helpful
But i actually need measurement to see how much i need to cut
Posted on: 2016/2/24 12:00
Not too shy to talk
hey mate, I too am in the process of doing this conversion so far i have found 3 different measurements from the internet regarding r31 width from 1405mm, 1430,1450. i will be reassembling my diff this weekend to measure myself. will let you know what measurement i get. i also have a standard ute diff to measure
Posted on: 2016/2/25 11:17
It depends on which part of the R31 diff you measure: drum-to-drum, axle tube width, or flange-to-flange
And depends on which R31 diff you measure: R31-borgwarner or R31-japan
Posted on: 2016/2/25 22:32
From Albury
there is a blow by blow description on here somewhere about shortening one axle and using the other on the other side.
Somebody cleverer than me might be able to find the post.
Probably overkill unless you have got serious horsepower though.
Posted on: 2016/2/26 5:05
Definitely overkill it weighs lot ... until you get a CA18DET built up, then you need it, and it's stronger than a Hilux unit, it was the factory axle behind 5-liter V8s in USA
Posted on: 2016/2/26 6:01
From Warburton vic
The Borg Warner where used here as well in Aussie v8s. The strong ones had 28 spline axles. They also had cone type LSDs witch wearnt that good. If you get 28 spline axles & eaton tru track LSD then you've got a strong Borgy
Posted on: 2016/2/26 20:29
Not too shy to talk
My diff is a Borgwarner 28 spline LSD and measures 1465mm from rotor to rotor
My stock 1200 ute diff measures 1305mm from drum to drum
I will be running a stroked ca18det in my ute, hence the upgrade
jpg  25.jpg (130.39 KB)
14425_56d14c1419ae2.jpg 2448X3264 px
Posted on: 2016/2/27 7:11
