« 1 ... 28 29 30 (31) 32 33 34 ... 49 »
Re: Turbo EFI A12 for under $1200. Discussion thread
From Mordialloc Victoria 3195
Unfamilia wins with his 'Big bang Theory'
Posted on: 2016/2/28 8:53
keep it simple
Do I get the blonde chick now?
Posted on: 2016/2/28 9:00
From Ballarat Victoria
Mmmm, where do I start....Finally got it to run properly at about 1am this morning with the help from a few guys from on here! too late to run it for long.
Had an hour this morn before Leigh and I went to Ziggys for the BBQ lunch in Melb, so roughly tuned it to get a figure. The 800cc injector ran out of duty cycle, it made about 70-80Kw but didn't get a log of it.
We fitted the larger injector with about 10 mins before we had to leave. I was loading it up a bit to check mixtures at the top end. mixtures and injector duty cycle were much better but in our haste had forgotten to hook up the boost line to the waste gate... Result was about 27Psi boost and a lifted head/damaged gasket. No HP figures unfortunately.
Ive just replaced the gasket and unblocked a few water passages in the head and block. I'll tune it properly tomorrow and post the results at 12Psi and 15Psi.
jpg  Blown head gasket, resize.jpg (189.49 KB)
6746_56d2cf4522d87.jpg 581X778 px
jpg  A12 Block after lapping, resize.jpg (174.47 KB)
6746_56d2cf518d1fc.jpg 581X778 px
jpg  A12 Head after lapping, resize.jpg (120.88 KB)
6746_56d2cf5d8cf7d.jpg 581X581 px
Posted on: 2016/2/28 10:29
VIC DYNO HIRE
From Adelaide
What did you lap it with? Have you got a flat stone, or a lapping plate, dor lap them together or know another trick?
Posted on: 2016/2/28 20:46
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
I used a diamond lapping plate. It's a bit dodgy using it on an assembled engine, but for this $56. eBay engine I'm not too fussed!
Posted on: 2016/2/28 22:30
VIC DYNO HIRE
From Adelaide
Flatness is the main concern, the gasket should fill all the surface flaws. I've learned a hell of a lot about dynamic sealing surfaces in the last year! I've been developing a rotary valve at work all that time, so much more to it than meets the eye.
Be interested to see how it goes since this is the level of tooling I have in my workshop for now. I'm sure it'll be fine.
Posted on: 2016/2/28 22:53
27psi! well old HG did its job!! 70-80kws roughly tuned
maybe more than my stab at 76kws tuned & closer to 80-82?
I feel as edgy as this frog waiting for a bus
what box to contain the new found force?
LambD- Dunstans personal dream was to use 2 x L4s
for his rotary valve engine since he unhappy the hoeden 6 limitations http://www.thegreymotor.com/2014/08/dunston-rotary-valve-head.html
Even reminds me of Sykines / Lags first offering of an A inj mani
http://3.bp.blogspot.com/-duwu2gfr94g ... /X3KYgac3j3Y/s1600/11.jpg
Posted on: 2016/2/29 3:35
Edited by D on 2016/2/29 4:30:45
From Adelaide
It's not an automotive rotary valve, something that goes in a medical instrument since that's what I do, cancer diagnostic machines. For a little while longer anyway.
Edit: sorry to stray off topic.
Posted on: 2016/2/29 6:52
Edited by lamb_daiquiri on 2016/2/29 7:22:56
From Lyngby, Denmark
Hey D
Which unit is the EFI one? There is missing alot of pic's on their site and im very interested in one as im doing efi in a little time :)
Posted on: 2016/2/29 17:17
Rowland does not list an EFI manifold
The photo D showed is a van Vuuren EFI manifold
Posted on: 2016/2/29 21:08
