Back in 1953 at the porsche Porsche factory
"the previous VW-based 1,100 cc (67 cu in) flat-four, used in the contemporary 356 and rated at 38 hp (28 kW), hit the limit of its potential.[4] Porsche realized it needed something all-new.[2] The brainchild of Dr. Ernst Fuhrmann, later Technical Director, it was hoped to achieve an "unheard of" 70 hp (52 kW) per 1 litre (61 cu in),[4] relying on hemispherical combustion chambers (what would be called hemi in the U.S.) and 46 mm (1.8 in)-throat 46IDA2 two-choke[6] Weber carburetors to generate 112 hp (84 kW) from the 1,500 cc (92 cu in) four-cam engine.[4] The 1.5 liter weighed 310 lb (140 kg) dry, eventually producing 180 hp (134 kW). A complex design that proved "very taxing" to build and assemble,[4] but very durable, it was used in 34 different models, including 550 Spyders, 356 Carreras, and F2/1s.[4]"
"probably the most complex four-cylinder" ever
Now 2016 in a man cave in Ballarat using a 53 whatever dollar A12
with very simple architecture albeit modern massaging achieves
more than 70hp per litre to power even simpler 1000 and 1200s.
Mission accomplished agreed but it does not stop here...
