Browsing this Thread:   4 Anonymous Users
« 1 ... 38 39 40 (41) 42 43 44 ... 49 »
Re: Turbo EFI A12 for under $1200. Discussion thread
From Melbourne AUS
id be interested in a kit if they become available.
out of interest, what sort of power before the standard clutch would give up? and with a decent clutch what will the gbox hold?
Posted on: 2016/3/15 9:53
1973 B110 A12
From Melbourne, Australia
Got a kit for non-turbo efi? I'd be keen. Had a gutful of carby daily driving the mustard coupe. A15 motor.
Posted on: 2016/3/15 9:58
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Ballarat Victoria
Re the clutch, I'm going to try to put two SH diaphragms into one SH pressure plate. All in the name of keeping it cheap. It should have nearly twice the clamping pressure. It may not be possible, but ill have a go at it.
Posted on: 2016/3/15 10:13
VIC DYNO HIRE
From Creswell, Oregon USA
Simon after seeing your results I am going to put the 15-lbs pressure wheel back on my Novi-Super charger. Rebuild the little A12 with some ARP studs, and a mild port on the head.
If one was inclined to get a better cam, what might you suggest outside your $1200.00 budget for a later expense?
Posted on: 2016/3/15 13:54
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
133kws and 213nm of torque thats more than any full nismo tomei race setup A12 for a 10th of the price, totally nuts. Now that its on soft suspension setup with drums any change of a quarter mile run? :) only kidding
Posted on: 2016/3/15 14:35
From Adelaide
Now that sounds like a lot of fun. I'm pretty much flat out at the moment though so I'd just about have to take time off work to do it. Let me think about if I can make it happen.
Posted on: 2016/3/15 20:59
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Moorebank
Hi guys new to forum
Simon very impressed with what you have been doing, I'm also interested in a injection kit.
Also do you have any of the super charger kits?
Posted on: 2016/3/15 23:43
A run down the 1/4 could be interesting. I'm not sure how the gearbox would hold up. Might do a 13 on the stock 12" tires.
Sleepa, I have never played with super chargers on these engines. I can supply some bits to people who want to build there own. But don't really want to supply full kits with ecu, turbo, wiring etc. it just takes too long to build looms, turbo manifolds and driving around to source parts etc.
The $1200. Figure is what it would cost for materials only(you finding them yourself) The idea is for people to build their own. If I was to do everything you could more than double that figure unfortunately.
Posted on: 2016/3/16 4:03
VIC DYNO HIRE
Datsuns are for dyi if possible this is an excellent guide and results
prove what is possible if you are willing and learn yourself.
Its a real pity no one has cast a turbo mani for the A series like
the one Sykine has done here but thicker walled of course.
A 1/4 mile run would lunch either box, diff or both :( would be fun
on a trailer for an outing, lil 12 rubber drawing 11s with a locker :)
If your not too worried about the tunnel that T-5 5 speed might be
worth considering with an auto bell and I can still source a H190 lsds
for a shortened H190 from a variety of cars which you can cut and shut
with your ability. The curve from that sucker will be alot of fun.
Posted on: 2016/3/16 4:15
Standard diff should be fine with a turbo A series. That's all I have in the circuit car and do 7000rpm launches every race start, albeit with a touch of deliberate clutch slip.
Posted on: 2016/3/16 4:41
VIC DYNO HIRE
