Wanting a turbo manifold or turbo setup for a12
Have a datsun 1200 a12 standard looking to put a turbo on either chasing up a manifold or turbo set up willing to pay need asap
Posted on: 2016/8/22 13:38
Re: Wanting a turbo manifold or turbo setup for a12
From Ballarat Victoria
I'm currently assembling a draw through carb turbo setup on an A12. It has a new turbo manifold and rebuilt turbo. It will be sold as a complete engine and kit including plumbing, carb, dizzy, head studs etc. it will be Dyno tuned before it's sold. $1300.
Posted on: 2016/8/23 0:53
VIC DYNO HIRE
What a deal! what carb?
Posted on: 2016/8/23 2:35
From Creswell, Oregon USA
Holy hell that's a great deal!!
Posted on: 2016/8/23 3:06
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
What would you charge with installation..
Posted on: 2016/8/23 6:34
If you can get the car to me, another $200. So $1500 plus the cost of building an exhaust. The cost of the exhaust system would depend on what size and material you want.
EDIT: The $200 for installation is if your clutch and cooling system is up to it.
Posted on: 2016/8/23 7:23
VIC DYNO HIRE
What type of numbers do you wreckon the motor would be able to handle
Posted on: 2016/8/23 8:13
It will probably make about 100Hp atw with the carb and unleaded at 12Psi. A standard A12 makes about 28-32Hp atw on my dyno.
The same engine/turbo made 190Hp with a single injector using E85. Ive taken off the ECU and wiring and i'm fitting a CD Stromberg Carb and refitting a distributor.
This is the engine: https://www.youtube.com/watch?v=S2m4xyNgPPQ
Posted on: 2016/8/23 9:15
VIC DYNO HIRE
Sounds awesome. Keep us in the loop, I'm keen!
I must admit the efi version looked like the goods but I hate electrics and they hate me. Nothing wrong with a carby! What sort of timeframe do I have to get this past the handbrake?
JD
Posted on: 2016/8/23 12:55
lucky bugger who gets this setup
Posted on: 2016/8/23 13:46
