« 1 ... 43 44 45 (46) 47 48 49 »
Re: Turbo EFI A12 for under $1200. Discussion thread
Quite a regular
From Long Beach, California
Would this build thread be possible to mimic on an A15 with pretty much the same work?
Posted on: 2016/8/24 23:57
Yes, it may work better on an A15
* the A15 (usually) has a water-heated intake manifold, so no flat spotting
* MicroSquirt/MegaSquirt can use the standard A15 (USA) distributor VR sensor for EFI -- no need for the special distributor wheel sensor & coil packs. Lock the mechanical advance mechanism and do all advance/retard in the Mega Tuner
Posted on: 2016/8/25 6:32
From Sydney, NSW
Would the throttle body size need to differ?
A lot of guys in south Africa tend to use a polo throttle.
And did the hall effect dizzy make the final cut? Its a neat option!
I'd love to find something that has IAC inbuilt
While I'm waiting for the buffalo guys to get back to me I'm keen to tinker
Posted on: 2016/9/5 23:19
The Hyundai throttle body will work fine on an A15. It's 40mm, about the same flow (?) as a Weber 38/38 (the Weber has choked throttles)
Posted on: 2016/9/6 0:18
From Sydney, NSW
Posted on: 2016/9/6 0:22
From Creswell, Oregon USA
It wouldn't be very hard to integrate a IAC to this kit.
If you make a spacer thick enough to side mount one.
Posted on: 2016/9/6 0:26
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From Sydney, NSW
Just wondering if anyone had sikyne's email or facebook details? I'd love to have a chat
Posted on: 2016/9/6 0:27
You can buy my injector manifold from me. Its the stock unit with two injector bungs welded in.
Has a CNC spacer already too.
Posted on: 2016/9/6 0:38
Parler @MDMachine
thats a nice setup Matt pity Im datsunless and instead MGd
Posted on: 2016/9/6 11:29
From melbourne
Hey D you back in OZ ?? call me
Posted on: 2016/9/6 14:40
