dead 210 locally: what should I acquire?
Local junkyard just got a 210 with rear-end damage. I'm going to pull the 5sp trans and maybe the head. Anything else that is hard enough to acquire that it'd be worth removing?
Posted on: 2016/10/15 18:44
Re: dead 210 locally: what should I acquire?
these are useful for a 1200
* electronic ignition distributor
* 245mm brakes & struts
* arm rests
* carburetor
* 2-door side window rubber seal
* ignition switch for 1972-1973 1200s
* seats
* 3.454 final drive
Posted on: 2016/10/15 21:26
From Midway City, California
#OOPS#, most of the front suspension should be usable, no?
Posted on: 2016/10/16 0:51
if it was easy to restore, they would call it chevrolet
don't piss off America, or we will bring democracy to your country
Yes, unless it's worn out ...
* LCA is same as late 1200, takes the late balljoints
* Balljoints fit the large knuckle arms
* Knuckle arm fits 2" struts & late LCA & B110 tie rods
This is what is used to swap late struts (210, S13, 810, etc.) See SAP
* Swaybar is too wide for a 1200
* steering linkage? unknown. Tie-rods might fit
Posted on: 2016/10/16 1:11
I'll grab the carb. For me the rest is less useful (I have a 210 drivetrain in an old british sportscar) but if they're easy I'll grab 'em to keep them out of the crusher.
Thanks for the suggestions.
Posted on: 2016/10/16 3:34
From Las Vegas USA
The alternator bracket......grab that , mine broke and I don't have a spare, hint hint.
Tom
Posted on: 2016/10/16 5:24
it still has the alternator bracket
jpg  Datsun B310 wagon.jpg (64.98 KB)
174_580306f736611.jpg 600X450 px
Posted on: 2016/10/16 5:50
From Las Vegas USA
Actually that style bracket I have 4 of. The GX head on the motor doesn't have a bolt hole or even boss for the bolt hole. My spare GX head has the bolt hole boss but no hole. i was using a straight bracket bolted to the thermostat housing, that one must have been an A12 bracket. Time to fab an adapter.
Tom
Posted on: 2016/10/17 5:53
This is the later style
early & late adjuster bars
B110 bar is much longer
Posted on: 2016/10/17 6:54
I swapped my alt to the other side and switched for a newer alt for wiring issues and ended up cutting and rewelding mine into a horrible mess. Nowe I wish I had left it stock and just fabricated one from scratch.
Posted on: 2016/10/21 19:26
