« 1 (2)
Re: eNgine swaps
From Las Vegas USA
Dave looking at the manifold it would be easy enough to flip the upper half sothat the issue of the throttle body being against the fire wall is not an issue. Also looks like I could fit the flat slides of my A15 and run a simple crank fire ignition.
Regardless as long as I'm running vintage it is something that I wouldn't even consider.
Tom
Posted on: 2017/1/14 4:53
Re: eNgine swaps
And since is has a Cam Position Sensor, it already has the needed crank-fire hardware
Posted on: 2017/1/14 5:15
Re: eNgine swaps
is there a way to run the 71 series box as the frontier box is super massive and heavy
Posted on: 2017/1/14 12:15
Re: eNgine swaps
Sure, sikyne ran a 71 behind an A12, it'll work with any engine short of V8
Posted on: 2017/1/14 20:32
Re: eNgine swaps
Not too shy to talk
From Hartford,CT USA
All swaps I found online do not come with ECU or harness at all!?
Posted on: 2017/1/14 20:37
Re: eNgine swaps
Right. So go to a wrecking yard and buy a harness and ECU with matching MAF. Or you can roll your own ($400 MegaSquirt2 and wiring). MAFs are cheap on RockAuto.com
Best way perhaps is to go to a PickNPull or LKQ and buy complete engine with everything
Pick N Pull prices (2017, Windsor California):
* Engine F-Inj W/Accessories Car $169.99 + $49.99 core
* Transmission Rwd (Std) Car $99.99 + $29.99 core
They have six Frontiers in California. Whether they are 4 cylinder 2WD (and still have the harness/ECU) is not listed
Pick N pull also has dozens of 2002-up Sentras in California. Some of which had QR engines. These are fly-by-wire so you'll need the accelerator pedal stuff to run the factory ECU
Posted on: 2017/1/14 22:04
Re: eNgine swaps
cheaper than in Japan to setup a QR you guys are blessed
Posted on: 2017/1/17 1:13
Re: eNgine swaps
Was working on an SE-R today. It has a neat features:
* only three vacuum hoses (tank vent valve, brake booster, port butterflies)
* a sealed throttle plate, works with the stock Nissan ECU or with MegaSquirt
jpg  HITACHI ETB0003.jpg (117.03 KB)
174_58a283b36c4b6.jpg 1024X907 px
Posted on: 2017/2/14 4:12
« 1 (2)
