Datsun 120Y / B210 OVERHEATING .... help!
No clue what to do, My 120y keeps overheating.. and its getting worse =\ .. stays at normal temp for a good 10-15minutes then goes from half way to near the max temp line.... (cold/hot day dosen't matter but worse on hot days)
here is what I have done so far:
New head gasket
New Thermostat
New waterpump
Flushed coolant like 1982429753238795 times (stil crap in radiator.)
Valve timing
silicone hoses
Next thing I'm going to do is replace the Radiator and temp sensor... but what is everyone elses thoughts?
Btw the car runs perfect!
Anthh
Posted on: 2017/1/26 10:06
Re: Datsun 120Y / B210 OVERHEATING .... help!
From Mordialloc Victoria 3195
Is it actually overheating ?
Alot of multimeters come with a thermal probe ? can get cheap infra red thermometer from fleabay - I have one - works ok
http://www.ebay.com.au/itm/Digital-No ... 3b70fd:g:fzsAAOSw4GVYOOLr
Sounds as though you're reasonably handy with the spanners having replaced head gasket
so I assume You've checked if the waterpump is actually pumping good flow through the radiator?
IE: Run it with the radiator cap off and see if swirling through the top of the radiator after the thermostat opens?
Posted on: 2017/1/26 21:51
keep it simple
Disregard everything I wrote here - just read your 120y story
Posted on: 2017/1/26 22:18
keep it simple
I second trying to find the cause. A digital thermometer will tell you more, I bought mine for $12 from Harbour Freight china shop, point it at cylinder head and see what actual temp it
Sometime gauge reads towards Hot while engine is not actually running hot
But most often this caused by the radiator or thermostat and not by the engine (head gasket/timing/water pump can be a problem, but is less likely). You can test the radiator and thermostat for no cost. See our tech article: Temperature Tests
Posted on: 2017/1/26 22:25
Bought a new aluminium 3 core radiator today and it solved all my issues :)
Picked it up for $139 at there warehouse @ Roadstar Automotive in Hornsby heights!
http://stores.ebay.com.au/ROADSTAR-AUTOPARTS
They also have stainless steel header for $199 ! im buying one next week!.. but they don't advertise it on ebay
They only have like 4 headers left
They also have electric Dizzy for $79 from memory
Posted on: 2017/1/27 3:50
Good price, and 3-rows indicates it should cool better than new stock radiator
jpg  s-l1200.jpg (117.85 KB)
174_588acc8b186fc.jpg 900X900 px
Posted on: 2017/1/27 4:25
From melbourne
I had similar problem and replaced everything, pump , thermo , had it flushed etc. Except radiator cap and that was problem .... It did not really over heat just ran really high . You say engine is running fine , so not the timing and wrong plugs
Posted on: 2017/1/27 4:41
temperature isn't going past half way now lol. :)
well worth the moneys.
Posted on: 2017/1/27 4:45
Those Ali fleabay radiators work a treat. On the 1200 you either have to space it out by 6mm, or lift the holes 6mm to make it fit - no big problem for the gain
Did you have to do it on the b210?
Posted on: 2017/1/27 6:40
keep it simple
Top bolts fit 100%
I haven't got any bottem bolts in, for the moment i have cable tied them till I get to work then I need to move the holes to suit on the bottem
Posted on: 2017/1/27 7:22
