Car Engine Dies when it is about to stop but idles well on stop
From Sri Lanka
Hi Guys
I have a problem with my b210 , it sometime dies when it is about to stop while moving , but idles smooth when it is just kept without moving anybody have an idea what would be checked ?
thanks
regards
sumith
Posted on: 2017/5/30 8:05
Re: Car Engine Dies when it is about to stop but idles well on stop
Does your B210 have an automatic transmission?
Posted on: 2017/5/30 8:17
From Sri Lanka
Hi DD
No it is Manual
thanks
regards
sumith
Posted on: 2017/5/30 8:37
This problem -- idles well but sometimes dies while slowing to a stop -- is common with automatic transmissions. It is causedT by a vacuum leak
Less common with manual transmission, but can be the same problem in conjunction with a low idle speed. Temporarily you could raise the idle speed
Best to look for and plug the leak (or fix the leak). See Vacuum Leaks for details
Posted on: 2017/5/30 8:42
From Biloela, Sunshine State
Vacuum leaks are related to the fuel system, so how would it's transmission type affect it? (We are talking about carburettor vacuum leaks aren't we?)
Posted on: 2017/6/2 4:19
That's a good question. I've wondered if it's because the auto puts a slight load on the engine (there's no load when you have the clutch pedal depressed)
Posted on: 2017/6/2 4:56
Since your car's a manual the possibilities for auto stalling/dying don't apply.
Next time it dies cut the engine immediately and check the fuel level in the carb. Float level maybe? Otherwise there may be some crap getting into your idle circuit but not enough to seal it.
Posted on: 2017/6/2 5:11
From Sri Lanka
Ok Guys
I have checked all my vacumm lines nothing wrong with them they look good, i will check it float and see tomorrow i noticed today that just before it dies it shakes a little high and die soon if i dont paddle the accelarator, when it is shaking if i gas it p it will keep it idle fine.
thanks
regards
sumith
Posted on: 2017/6/3 16:15
With that symptom check the linkages, smooth cable action and idle stops. Also if you're using points check and reset or renew them. Do the condensor too.
Posted on: 2017/6/4 0:09
From Sri Lanka
Hi Guys
It Seems problem sorted out , i did few things dont know which sorted out my issue
Adjusted Float level which was little higher after the repair of fuel pump
Cleaned all the spark plugs.
Removed Carb Slow get and Cleaned it and fixed back
Replaced all the vacuum horses with new ones
thanks
regards
sumith
Posted on: 2017/6/4 13:31
