(1) 2 3 4 »
Sequential shift kits
From Creswell, Oregon USA
S1 Sequential makes a really nice kit for the Tremec T56 but I would like to see if our community could come up with a similar idea for the Datsun.
This would be a very fun item to DIY
After a crack at the cross flow head BTW.
Posted on: 2018/6/20 0:10
Re: Sequential shift kits
From Las Vegas USA
I gave thought to this many years ago because as I motorcycle guy / racer first I've always thought H pattern gearboxes are an abomination (no strong opinion there)
So here is my deal on sequential boxes; with the motorcycle powered sports racer once I left the pits I'd go up and down the box with out using the clutch. This naturally allowed me to left foot brake. While I'm capable expecting flawless heel and toe downshifts I don't get any big thrill out of it in and of itself.
On the surface it seems simple enough to come up with a shift drum mounted externally to move the shift lever but what do we gain from it........ Besides the cool factor of course.
One possible thing I can think of is paddle shifters making it easier to keep hands on the wheel while shifting.
Posted on: 2018/6/20 1:49
Paddle shift kits would be a hoot.
Posted on: 2018/6/20 19:42
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
My MR-S has a steering wheel shifts, its a hoot but
the setup is very complicated if something goes wrong.
There are hydraulic pumps, solenoids, ecu and hoses
that run this system and motorbikes are mechanically
operated which is infinitely better simpler etc.
Years ago I wondered if one could use the strong drag
harley davidson aftermarket boxes onto an A series
they are cheap and stronger than some japanese boxes
140 ci or 2.3L twin has a fair bit of torque!
175lbs!!!!!!
http://www.ultimaproducts.com/140engine.html
torque rating is the key element and 2.3L
would have more torque than any A series.
'6-Speed LSD Overdrive'
Complete Natural Aluminum and Chrome Transmission with Chrome Covers
Latest 2017 year model.
We don't offer 2003-05 models as "new", like our competitors.
Case is cast from 356-T6 aluminum
Chrome plated Forged Billet Trap Door
Built with German Made Split Main and Counter Shaft Bearings
NOT CHINESE
At last there's a solution that reduces vibration and improves acceleration. When the bike hits freeway speeds, simply shift into 6th gear and lower the cruising RPM. Freeway cruising becomes more enjoyable with reduced vibration, increased gas mileage while keeping the engine in the heart of its torque band. This 6-speed transmission is complete, and ready-to-install
Close ratio Tranny assembly.
1st gear -2.94
2nd gear -2.21
3rd gear -1.6
4th gear -1.23
5th gear -1.00
6th gear -0.86
https://www.demonscycle.com/6-speed-na ... ssion-for-harley-davidson
Posted on: 2018/6/21 1:37
Edited by D on 2018/6/21 1:52:53
Edited by D on 2018/6/21 1:54:15
From Las Vegas USA
D motor cycle style shift drums are very simple, you wouldn't need anything more than a control cable.
Posted on: 2018/6/21 1:43
Exactly, you could mount your shifter almost anywhere.
The Ultima website rates the 140ci v twin at 175lbs!
165bhp but these trans also sit behind turbo drag v twins
http://www.ultimaproducts.com/transrsd6speed.html
I wonder if someone knows something about these boxes
they are cheap at 6-700usd on ebay, gearset replacements at 500usd
2kw starter could be used from ultima
just needs an adaptor for an A series auto bellhousing
flange for the prop and clutch spline and input shaft considerations etc
The whole cost could be easier than sourcing and rebuilding old T50 toy boxes
buying a kit for them and fitting them only to have a H pattern.
Posted on: 2018/6/21 1:56
From Los Angeles,CA
No Reverse..... :(
Posted on: 2018/6/21 11:15
There are plenty of reverse kits but was told by an electric engineer
starter motors are DC and easily to setup for reversible rotation
using a switch that can be setup using first gear.
These are available but I would prefer a high torque starter
with a relay which is cheaper to reco every few years if need be
than to pay 3 times the price of the box they run
http://leolamotortrike.com/content/harley-reverse-gear
Posted on: 2018/6/21 15:08
Posted on: 2018/6/21 15:13
Parler @MDMachine
Yep I think starter motor is the way, very cheap which is the aim
of datsun folks so a harley 6 speed, auto A series bellhousing
connected via adapter plate, clutch and imput shaft spigot change.
Starter motor mods to go forward or reverse as used in electric go karts
http://www.diygokarts.com/engine/car-starter-motor-conversion.html
Sequential shifting all mechanical sounds sweet!
Matt
Posted on: 2018/6/23 3:14
(1) 2 3 4 »
