FS5W60L gearbox parts required
Not too shy to talk
Hi all,
I’m after some parts for the 5speed or places that will be able to help.
The part numbers according the exploded diagram in the wiki section are as follows:
3 x 32602
3 x 32608
1 x 32258B
1 x 32245
1 x 32604
Finding it a bit hard to get any gearbox specialists to help source parts or info.
Any help greatly appreciated!
Thanks guys.
Posted on: 2019/1/23 2:05
Re: FS5W60L gearbox parts required
Nissan part numbers
32602-32200 SPRING-SHIFTING INSERT 73 cents from Nissan USA
32608-H9000 INSERT-SHIFTING
32258-H9001 HUB SYNCHRONIZER-1ST & REVERSE
32245-H9000 GEAR-REVERSE, MAIN SHAFT
32604-H9000 RING-BAULK
Balk rings (synchro rings) are fairly common and same as the 4-speed. eBay or AliExpress http://datsun1200.com/modules/mediawi ... itle=Synchros#32604-H9000
https://www.amayama.com/en/part/nissan/32604h9000
The rest of those parts? I'd just buy a used 5-speed with a broken case or bad bearing -- in order to get these parts
Posted on: 2019/1/23 3:21
Someone out there might have some -- you might post a Classified
jpg  32604-H9000.jpg (84.66 KB)
174_5c491137275f6.jpg 640X480 px
jpg  32604-H9000_.jpg (14.77 KB)
174_5c491142afa61.jpg 400X300 px
jpg  FS5W60L parts.jpg (122.73 KB)
174_5c491154107c1.jpg 1200X900 px
jpg  H90 hubs (with springs), synchros, inserts, main shaft.jpg (123.91 KB)
174_5c491190818af.jpg 1200X900 px
Posted on: 2019/1/24 1:15
Not too shy to talk
Thanks for the lead mate!
Bulk rings and shifting springs I have found, the rest is proving to be quite hard!
Still trying!!
Posted on: 2019/2/5 0:13
These are the only parts you still need?
1979 Datsun B310 (Sunny/210) dogleg 5-speed
* #32245 Reverse Gear
* #32258B Sychro hub (1st & Reverse) with three 32602 springs & three 32608 inserts
jpg  26276.jpg (76.75 KB)
174_5c74cc79b5219.jpg 864X650 px
png  FS5W60L 5-speed Reverse Gear & Hub.png (36.44 KB)
174_5c74cc8aca472.png 604X630 px
Posted on: 2019/2/26 5:20
From Fort Worth, Texas
60L reverse gear is 32245-H9000 GEAR-REVERSE, MAIN SHAFT
60A reverse gear is 32245-H9700 GEAR-REVERSE MAIN SHAFT
What is the difference?
Posted on: 2019/2/26 18:09
H90 = 60L
H97 = 60A
60L reverse gear:
* moveable gear
* fits next to 1st gear
* fits over the rev/1st synchro hub (gear is splined)
* gear is machined with selector channels to move the gear
60A reverse gear:
* gear does not move
* fits next to 5th gear
* Conventional type free-gear
* Reverse is synchronized
Posted on: 2019/2/26 21:28
Thanks DD. Was thinking they were interchangeable and he would be able to source other gearboxes for parts. I haven’t come across any 60Ls. Not many of those around.
Posted on: 2019/2/27 5:00
From Fremantle, West Australia
I might be able to help with 60 L bits
Posted on: 2019/3/11 3:06
