« 1 (2) 3 4 5 »
Re: Wife wants to keep the Auto trans.
From Adelaide
Probably way too big but the 6L80 transmission in my Commodore has a huge spread of ratios. I believe the modern transmissions require calibration (tuning) for the application though.
Posted on: 2019/2/13 9:04
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
78mm bore A15 would be a fine auto engine
The 6 speed toyota rwd automatic is actually
smaller than the older 4 speed and equal to
the 5 speed and removable bellhousings.
https://www.jdmnewyork.com/product/toy ... ssion-jdm-1jz-gte-1jzgte/
Posted on: 2019/2/13 11:08
From Creswell, Oregon USA
I like the Toyota transmission.
Might as well go with a Beams or 1JZ with it instead of adapting a Q motor.
Posted on: 2019/2/13 11:54
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Do you mean Nissan QR engine? QR25DE comes with RWD automatic from D40 Frontier
Or Nissan VQ engine?
Posted on: 2019/2/13 13:33
QR motor.
I really haven't done enough exploration as to what is available. Had no idea about the Frontier
Posted on: 2019/2/13 16:04
Parler @MDMachine
There also is the Diesel YD engines with the 2.5 max
figures of 190hp & peak 332lbs of torque @ 2000rpm!
Youd probably need a 2.75 to 1 diff ratio :)
The 2.2 YD version would be fine and shorter height
shorter stroke with choice of 5 or 7 speed autos
Never heard of a diesel 1200 coupe but that kind
of engine with super highway diff would probably
get you 60-70 miles per gallon
Posted on: 2019/2/14 13:28
I cant find the YD22DD motor in the US from all my google searches.
UK, AUS, Japan are only markets it shows available.
Posted on: 2019/2/14 16:16
Parler @MDMachine
Darn youd thing USA would get diesel X-trails and D40 Navs
how about 2.2 turbocharged perkins
eg.
https://www.perkins.com/en_GB/products ... -syncro/17-22-syncro.html
or is there a cheap one from a local usa car that you could use?
nissan cd20et is not a bad motor I thought was avail in USA, Canada & mex
its based as a beefier ca18de design quite compact and simple but if you
have an A15 Im sure itd make a good daily anything around 280lbs engine
weight like the ka24de youd probably consider the equal weighing vg20e
http://datsun1200.com/uploads/photos/26408.jpg
Posted on: 2019/2/15 9:38
I will have to look at some USDM diesel cars. I dont pay much attention to them.
Im excited to get the 1200 coupe home tomorrow.
Posted on: 2019/2/15 15:09
Parler @MDMachine
Congrats on you coupe purchase
No sense paying attention to USDM diesel. Diesel fuel cost more than petrol/gasoline in US. We don't get the small Nissan or Perkins deisels. VW had good performing diesels but turns out they were polluting 40x more than the competition
in the 1960/1970s US truck drivers preferred petrol engines - quieter, more power, more flexibility. However truck owners paying the bills preferred longevity and fuel economy. Hence why long distance trucking switched over to mostly diesel in the 1970s
Posted on: 2019/2/16 1:21
« 1 (2) 3 4 5 »
