« 1 (2)
Re: What happened to those billet efi manifold starters?
From Perth
anyone used those efi webers yet and know where i can get some ?
Posted on: 2019/3/6 10:31
http://google.com/search?q=Jenvey+EFI
Also sold in other countries including USA and AUS
The Jenvey Heritage DCOE throttle body ... includes a built in fuel rail, 350CC injectors, extension looms to bring the injector connector to the underside of the throttle body and a hidden internal throttle position sensor.
Please note that it is not advised to run the Heritage Throttle Bodies with engines running boost
Posted on: 2019/3/6 10:44
is there a big performance hit by having injectors
a bit further back away not on the flange so they dont
spray directly at the back of the valves
good question. spraying at the valve is best for emissions. Best performance is generally achieved by being a little farther from the head
Posted on: 2019/3/6 11:16
From Creswell, Oregon USA
I have some old 4 cylinder performance magazines that did a DYNO comparison of different injector positions. If direct chamber injection wasn't present then the one that created the most power was when the injector was in line with the runner pulsing horizontal with the runner like older F1 cars..
Posted on: 2019/3/6 12:24
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Neil I saw an article of the jenvey weber (hidden efi) on an L28
in a japanese magazine and the 32xhp was achieved at 7800rpm but
thats all I could make out.
The reason I asked is because it seems a bit complicated to
have them on a flange when you can have them an inch away
on the runner therefore have a design to also suit carbs
or port injection like on the older f1 fezza engines etc :)
Posted on: 2019/3/6 12:37
From Melbourne Vic
And herein lies the problems of chasing the 'best' design. boost changes everything, as does the cam, the ability to tune it manage the torque delivery etc. there have been some very basic designs that have made silly power it kinda depends on what your goals are and what restrictions you have in place (space/budget)
i love the look of the billet parts, but making a complete manifold might be a bit out of my price range. but if it makes a neat injector and rail setup and aids in the oval to round transition then im keen as!
this is very exciting stuff, its good to have some very skilled people playing with the old a bangers!
Posted on: 2019/3/6 23:16
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
I used to play with bike carbs back in the mid 90s with bike carbs
and many guys like yourselves have played with bike efi units which
most know are super cheap vs jenvey units.
If you can use the bike efi quads and twin x 2 then thats the way
to go to save overall costs.
A cnc manifold doesnt really make sense but flanges do for most of us.
There are twin cylinder engines with efi that could lend themselves
better for a compact flange to use those units as well but forgot the bikes.
Posted on: 2019/3/7 0:08
I will offer up a free intake design for the A12 that people can DL. Flange models too. These will be as generic as possible, but free.
Posted on: 2019/3/7 13:09
Parler @MDMachine
If the injector and fuel rail flanges can be made to suit
Alfa romeo v6 right bank inlet pipes then you can just
flip the plenum or pipes to suit the A series head.
I did the spacing and it was a winner but went to other
engine ideas instead.
The plenum lends itself easily you just weld/cover up
the 3rd inlet and cut off the 6th and plate it up
https://imgur.com/9WUD9Bk
There are plenty of Kawasaki twin inlets closer together
like the A series inlets that can be used for ITBs
https://i.ebayimg.com/images/g/PkIAAMXQAI9SLh0L/s-l1600.jpg
Posted on: 2019/3/8 2:18
Edited by D on 2019/3/8 2:44:53
« 1 (2)
