« 1 (2) 3 4 »
Re: 75-77 mm Flat Top Pistons for A12A ?
From melbourne
A shot in the dark
does J15 fit , they use a flat top , think a lower comp. then deck the block ??
Posted on: 3/10 14:03
From Hawaii, USA
75.5 bore, 32.5 compression height, short-skirt piston
Nissan K15 used in Nissan and Mitsubishi forklifts
pin bore is 20mm, instead of the 19mm of the A-series, so a small mod would be required
* $20 https://venusparts.en.alibaba.com/prod ... r_Nissan_12010_FU320.html
* http://www.k21engine-parts.co.uk/cont ... Crankshaft___Pistons.html
There are also dished versions of the K15 piston
jpg  Nissan-K15-engine-piston.jpg (55.69 KB)
174_5c85925165a5e.jpg 588X300 px
Posted on: 3/10 22:47
From Hawaii, USA
Yes J-series uses flat-top pistons
* J15 has 39.8 pin height so will stick up out of the deck 7.3mm
* J18 has 31.9 pin height (0.7 lower than A12A/A14) but is 80.5mm diameter and uses a larger pin
* J13 has 32.5 pin height same as A12A and is flat-top, nearly same as A12GX but different skirt design -- smaller bore than A12A
Posted on: 3/10 23:27
From melbourne
Saw these on ebay , they have a tiny lip and depending on cost , could be shaved.
https://www.ebay.com/itm/222265879138?ul_noapp=true
jpg  a14 piston.jpg (81.65 KB)
14887_5c85b5efbb141.jpg 584X498 px
Posted on: 3/11 1:12
From Melbored
the Isuzu ones are 28.5mm thats 4-5mm less than the discussed items
they handle boost well, are lighter and shaving block 4-5mm should
prob? not be an issue as A12 engines are thickly casted units.
Id check if PJZ has longer rods available as I recall he had some
126mm rods available at one stage which could be fiat units.
They would allow the A12 with A13 capacity to raise the redline
Fiat 500 126mm rods x 2 sets are cheap from alibaba or aliexpress
https://www.aliexpress.com/item/connec ... E&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_319_10059_10884_317_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_537_536_10902,searchweb201603_6,ppcSwitch_0&algo_expid=ebf4f576-c333-4ba2-bc44-b1207b3158ca-1&algo_pvid=ebf4f576-c333-4ba2-bc44-b1207b3158ca
same but doubled in price
https://www.maxpeedingrods.co.uk/high- ... necting-rods-conrods.html
specs are almost spot on to A12 rods
https://www.hurricanerods.com/products ... steel-connecting-rod.html
Engine: Fiat 500 Abarth Punto 1.4L T-Jet
Part Type: Connecting Rods
Center to Center Length: 129mm/5.079"
Big End Bore Diameter: 45.13mm/1.777"
Big End Width: 21.7mm/0.854"
Small End Bore Diameter: 18mm /0.709"
Small End Width: 21.7mm/0.854"
Beam Style: H-beam
Connecting Rod Bolt Diameter:5/16"
Approximate Connecting Rod Weight: 415g/piece
Advertised Horsepower Rating: 550hp
Quantity: Sold as 4 pieces /set
Material: Forged 4340 steel
Connecting Rod Finish: Shot-peened, Polished
Pin: Bronze wrist pin bushings
Wrist Pin Style: Floating
Cap Retention Style: Cap screw
Weight Matched Set: Yes ,Balanced +/- 1g
Magnafluxed: Yes
Private Label: Yes ,available
Custom design: Yes, accept
Rod Wrist Pin Style: Floating
Small end diameter:: 20.005mm
warranty: limited lifetime warranty
Posted on: 3/11 4:12
why you are slaves to Usury https://www.youtube.com/watch?v=FEheU28ea3c The Anzac Deception not know by modern Australians http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf ""
From Las Vegas USA
The issues caused by decking the block and milling heads to me are not worth the trouble they bring.
D I appreciate the information but I'm looking for off the shelf parts. I'm looking to get the max performance from what parts are readily available, if that maximum is a few horsepower less than custom parts so be it.
It looks like 76.75mm pistons are available via eBay, they appear to be the 1mm deep,dish which are around -2.75cc and with those it's possible to get the compression up to 10-1.
The goal is to get a near as possible 1300cc putting out around 90whp. The 1171cc GX motor with the flat slides and ported head made 73whp, so I think it's doable.mthe motor going in the car now is probably near 80whp.
I won't be doing anything until after my next race; I previously made the top 6 overall in the small bore group with the A12, I was finishing 12-15 seconds ahead of the cars behind me and about 12-15 seconds behind the cars ahead of me. If I manage the top 5 or 6 then I will leave the motor alone unless I'm within 4-5 seconds of the next group of cars
Posted on: 3/12 3:30
From melbourne
A few people on here say the Suzuki Vitara D16 turbo pistons fit straight in a A15.. I know they make a High Comp coated piston
11:1 for around $125 . Maybe something to investigate
Posted on: 3/12 5:37
From Melbored
If only going 76.5mm thats a good compromise.
Tom would you know if A series camshafts are
factory hollow units or just solid cast?
Posted on: 3/12 6:03
Edited by D on 2019/3/12 7:17:33
From Hawaii, USA
Will the K15 pistons work for you Tom? Nissan off-the-shelf flat-tops, correct pin height and inexpensive
A15 uses a different pin height than A12A
Vitara *dish* pistons are sometimes used to build a Honda D16 turbo motor
Honda D16 is 75mm bore. D16 piston compression heights vary from 27.4 to
30.7 (and rod length varies)
None have A14 spec pin-height
For an A15, the 30mm pin-height ones are D16Y7 (1994-1995 Civic Ex 1.6)
& D16Z6 (1992-1995 Civic Si 1.6). The piston total length is
longer than A15 piston
Unfortunately they are not flat-tops
Posted on: 3/12 11:16
From Melbored
Toyota K series are usually heavy things
very much like L series 38mm comp height
If you ran 73.25 pistons and A14 crankshaft
it gets you under 1300cc and you can use
some pjz forgies he had for sale recently.
However you prob want revs rather than torque
There was a tall A13 that uses the 77mm stroke
as well which is a small bore A14 block
Posted on: 3/12 14:19
« 1 (2) 3 4 »
