« 1 2 (3)
Re: 79 B310/210 auto to 4 speed swap questions
Good on ya. Should be more power and more driving fun
Posted on: 2019/8/3 12:13
From South Dakota USA/Trinidad and Tobago
Just fired it up. Seems to be running fine. I just unbolted the inhibitor switch from the auto n hooked it back up to the harness in park position. Will run it like that for now. Just gotta bleed n adjust the clutch. No idea how to do that and my help is gone today. I’m on my own
Posted on: 2019/8/3 21:52
3NE 2NR
congratulations, the first 4 speed someone has documented, keep it up
with this kind of detail and perseverance many can follow your efforts.
Posted on: 2019/8/4 2:25
Thanks bro. It’s running and driving. Shifts good even tho the bushings are shot(ordered new ones) and I think I need to bleed the clutch again. But it’s a million times more fun to drive. Been driving it around all evening lol. Still got put a boot in it n do the wiring
The 4 speed is temporary. As soon as I can get a 5 speed it’s out
Posted on: 2019/8/4 4:08
3NE 2NR
That's the spirit! whats the 5 speed from? suits the A series?
Posted on: 2019/8/4 10:46
B310 5 speed
Posted on: 2019/8/4 11:54
3NE 2NR
I take it all back! thought you were doing an Auto sorry!! :)
Posted on: 2019/8/5 5:11
Have to work on the clutch a bit. Have to bleed it again cuz it doesn’t feel right. The release point is still a bit close to the floor and feels like it’s an on/off switch when I step on the clutch. Not sure if I’m describing it properly. Also I see there’s an adjuster n lock nut on the slave cylinder. How do I adjust it properly?
Posted on: 2019/8/6 4:17
3NE 2NR
It is adjustment on both ends (first at transmission, then at pedal). The transmission end is same as 1200, adjust for 5/32" free play. Pedal height for b310 i dunno but it will be safe with 1" free play. If you don't have free play the clutch will wear out. see Hydraulic Clutch Adjustment
Bleeding is only needed for mushy pedal or grinding gears
Posted on: 2019/8/6 8:26
« 1 2 (3)
