« 1 (2)
Re: Tachometer mounting to Console
Putting the tachometer in the console isn't optimal. To see it you'd have to take your eyes off the road for longer than a dash-mounted tacho
The factory tachometer was not designed to bolt to the console. But it will fit if you make a simple bracket to hold it in place. Perhaps you could even use plumber's tape
spacer & home-made bracket
fitting
Posted on: 2019/9/4 21:19
10,000 rpm Tachometer
A match for the stock 8,000 rpm tachometer was sold by Nismo
jpg  Competition198442.jpg (68.85 KB)
174_5d70d4bf0bf30.jpg 600X853 px
jpg  42a.jpg (174.38 KB)
174_5d70d4cee755d.jpg 675X727 px
jpg  10K_tachometer-1.jpg (21.20 KB)
174_5d70d4fa1ca27.jpg 600X450 px
jpg  10K_tachometer-2.jpg (21.61 KB)
174_5d70d50fb2c60.jpg 600X450 px
Posted on: 2019/9/5 10:27
Re: 10,000 rpm Tachometer
Be careful when buying a used tachometer. This 10k tacho has the main power wire missing. Wires cut. bottom tab cut. All minor, but the power stud is missing too. Maybe can't be fixed
jpg  10Kaa.jpg (115.07 KB)
174_5d715b3c70d61.jpg 600X450 px
jpg  10Kab.jpg (39.56 KB)
174_5d715b4559d9e.jpg 800X800 px
jpg  10Kac.jpg (47.58 KB)
174_5d715b4dd5314.jpg 800X600 px
Posted on: 2019/9/5 20:01
« 1 (2)
