« 1 (2) 3 »
Re: Tachometer mounting to Console
Putting the tachometer in the console isn't optimal. To see it you'd have to take your eyes off the road for longer than a dash-mounted tacho
The factory tachometer was not designed to bolt to the console. But it will fit if you make a simple bracket to hold it in place. Perhaps you could even use plumber's tape
spacer & home-made bracket
fitting
Posted on: 2019/9/4 21:19
10,000 rpm Tachometer
A match for the stock 8,000 rpm tachometer was sold by Nismo
jpg  Competition198442.jpg (68.85 KB)
174_5d70d4bf0bf30.jpg 600X853 px
jpg  42a.jpg (174.38 KB)
174_5d70d4cee755d.jpg 675X727 px
jpg  10K_tachometer-1.jpg (21.20 KB)
174_5d70d4fa1ca27.jpg 600X450 px
jpg  10K_tachometer-2.jpg (21.61 KB)
174_5d70d50fb2c60.jpg 600X450 px
Posted on: 2019/9/5 10:27
Re: 10,000 rpm Tachometer
Be careful when buying a used tachometer. This 10k tacho has the main power wire missing. Wires cut. bottom tab cut. All minor, but the power stud is missing too. Maybe can't be fixed
jpg  10Kaa.jpg (115.07 KB)
174_5d715b3c70d61.jpg 600X450 px
jpg  10Kab.jpg (39.56 KB)
174_5d715b4559d9e.jpg 800X800 px
jpg  10Kac.jpg (47.58 KB)
174_5d715b4dd5314.jpg 800X600 px
Posted on: 2019/9/5 20:01
This 1000rpm tacho was for sale last month starting bid $1000 but i don't think it sold?
https://auctions.yahoo.co.jp/jp/auction/f1203024367
It has differences from all the others:
* No tell-tale pointer
* Does not say KANTOSEIKI TOKYO below x 1000rpm
* legend (x 1000rpm) is below the pointer instead of SE to the pointer
It also has tape where the dash bracket would normally be
jpg  10000 rpm.jpg (123.07 KB)
174_6909038bc3fa9.jpg 1168X1168 px
jpg  tape.jpg (130.19 KB)
174_690903995785c.jpg 1263X1263 px
jpg  patch.jpg (136.72 KB)
174_690903a1c6adb.jpg 1216X1518 px
jpg  back K.S.jpg (188.87 KB)
174_690903abc1dbf.jpg 1572X1344 px
Posted on: 11/3 19:34
GX tachometer
Datsun 1200 GX came with 6800 rpm redline. The other tacho has a redline that starts at 6400 rpm
the yellow line indicates you have revved beyond peak HP
The redline is higher than a non-GX engine as valve float doesn't occur until after 6800. This is because of the dual valve springs
jpg  GX tachometer (6800 redline).jpg (84.67 KB)
174_690a47275fd2e.jpg 864X864 px
jpg  tachometer mechanism.jpg (72.07 KB)
174_690a473aacd7c.jpg 864X864 px
jpg  adjustment screw.jpg (110.84 KB)
174_690a4753894f3.jpg 896X896 px
jpg  spring.jpg (89.12 KB)
174_690a4760c20cf.jpg 900X900 px
jpg  b.jpg (84.91 KB)
174_690a477d16ac4.jpg 864X864 px
jpg  c.jpg (75.73 KB)
174_690a478358321.jpg 864X864 px
jpg  d.jpg (128.04 KB)
174_690a4788d7d85.jpg 900X1200 px
jpg  e.jpg (113.49 KB)
174_690a4791a3864.jpg 900X1200 px
Posted on: 11/4 18:36
GX facelift tachometer
the 1972 JDM facelift brought a new font typeface to the meters, new taper-cone anti-glare gauge covers ...
...and new bold color bands for the yellow zone and red zone of the tachometer
jpg  H34.jpg (73.63 KB)
174_690a8b484166e.jpg 800X800 px
jpg  H34 adjustment screw.jpg (63.66 KB)
174_690a8b4e6e657.jpg 720X720 px
jpg  h34 installed in facelift dash.jpg (95.30 KB)
174_690a8bce6a782.jpg 800X600 px
Posted on: 11/4 23:27
Tachometer adjustment
The factory Datsun 1200 tachometer has an adjustment screw. A simple turn of the screw will raise or lower the indicated RPM. At the factory this was adjusted for a correct reading at a certaom rpm. However, as components age (in particular the capacitors) the reading may need adjustment.
Take a reading using a dedicated (accurate) Dwell-Tachometer, and if your tachometer is off, adjust it to match.
TURN
* clockwise: to lower RPM
* anti-clockwise: raise RPM
Try turning the screw 1/8 turn, and see if the new reading is what you want. You can compare the reading by connecting a dwell/tach meter to the engine, then adjust the tachometer to read the same.
Yellow Arrow points to the adjustment screw on the back of the case
jpg  adjustable resistor.jpg (111.63 KB)
174_690a8fb477430.jpg 896X896 px
Posted on: 11/4 23:43
Datsun 620 Tachometer
The tachometer for the Datsun 620 truck looks identical to the 1972 B110 facelift tacho with these differences:
* 7000 rpm redline
* Shorter brace tab and no top tab
* 1-wire signal with mini-harness
Unlike the B110 unit, it connects to the coil negative terminal like aftermarket tachometers. So if installing in a 1200 a new wire needs to be run out from the dash to the engine compartment.
It will accept the flat 1200 cover
In my 1200 ute, i left the facelift cover on for the anti-glare properties. The red and yellow colors matched my Momo Commander steering wheel
jpg  620 tachometer with anti-glare cover.jpg (110.96 KB)
174_690b7a9d70a7e.jpg 960X960 px
jpg  620.jpg (118.56 KB)
174_690b7aa70b5ae.jpg 1024X1024 px
jpg  620 BG wire.jpg (144.77 KB)
174_690b7ae33bfd2.jpg 1024X1024 px
jpg  620 connector.jpg (194.08 KB)
174_690b7af7c5251.jpg 1200X1200 px
jpg  620 brace tab.jpg (147.15 KB)
174_690b7b5d15781.jpg 1200X1200 px
Posted on: 11/5 16:36
10K tach
The Nismo 10000rpm tacho has a tab like the standard B110 tachometers:
Is the tab for earthing or for bracing?
This one has a straight tab which appears to be in the same place:
jpg  10k BACK.jpg (112.30 KB)
174_690d9418d0134.jpg 848X848 px
jpg  10k.jpg (169.05 KB)
174_690d942b20772.jpg 1248X1248 px
Posted on: 11/7 6:39
6500 rpm redline tachometer
This is a strange one. Bprojects sold this some years ago as a Sunny Truck tach meter.
* new style font and colors (1972)
* 5500 rpm yellow line
* 6500 rpm red line
It may be a 1972 PB110 (1400) meter. But how can that be? Surely the OHC L-series has higher redline? Not necessarily. The GB211 (1600) tachometer has a 6200 rpm redline, lower even than the A12!
Sunny Excellent 1600 brochure
The first three photos are a used unit. The other photos are a brand new Bprojects unit.
jpg  b110-tacho-003.jpg (24.81 KB)
174_690fe70a1a6be.jpg 640X480 px
jpg  b110-tacho-004.jpg (24.72 KB)
174_690fe71d5e62a.jpg 640X480 px
jpg  b110-tacho-005.jpg (24.90 KB)
174_690fe729a184f.jpg 640X480 px
jpg  b110-tacho-006.jpg (30.18 KB)
174_690fe7418c207.jpg 640X480 px
jpg  b110-tacho-007.jpg (32.57 KB)
174_690fe750e4515.jpg 640X480 px
jpg  b110-tacho-008.jpg (46.32 KB)
174_690fe758153df.jpg 640X480 px
jpg  b110-tacho-003003.jpg (33.76 KB)
174_690fe75e96a09.jpg 500X375 px
Posted on: 11/9 0:59
« 1 (2) 3 »
