A12 cylinder head-closed chamber-round port
From Fort Worth, Texas
This head came off of an A12 engine. No casting number. Any idea on specifications?
jpg  A12.cylinder.head3.jpg (77.57 KB)
20677_5e17f07431bb6.jpg 540X960 px
jpg  A12.cylinder.head2.jpg (99.57 KB)
20677_5e17f0813af91.jpg 750X1000 px
jpg  A12.cylinder.head1.jpg (72.93 KB)
20677_5e17f08fcb8b5.jpg 540X960 px
jpg  A12.cylinder.head.jpg (69.91 KB)
20677_5e17f096dfe26.jpg 540X960 px
Posted on: 2020/1/10 3:36
Re: A12 cylinder head-closed chamber-round port
From Las Vegas USA
Are the ports / valve stems shrouded. It's hard for me to tell but the combustion chambers look very deep and those where the FU / smog head.
Posted on: 2020/1/10 3:55
Not sure. Someone was offering it to me and sent pictures. Familiar with the deep chamber. Saw that on a H990 head (closed chamber/round port) which came off of a FU engine. Thanks for the response.
Posted on: 2020/1/10 4:10
The top A series racing guys that go all out here in Japan
use these kind of heads from their sunny a12 engines.
They favor deeper chambers and shape them like this
aftermarket chamber
https://www.streetmusclemag.com/image/2015/02/20150210_170551.jpg
L series version done by TK
https://i291.photobucket.com/albums/ll ... /P1141427_zps8dqvjjyk.jpg
The rules dont allow welding the chambers but allow
opening up the ports then using devcon to cover the
water galleries etc. so its easier to get this shape
from the humble a12 heads than the pricier h89 which
is used happily by street tuners instead.
Posted on: 2020/1/10 5:42
That is nice work on the chamber. Do they go with flat top pistons due to deeper chamber?
Posted on: 2020/1/10 15:14
That is a non-American engine
* using RHD cable clutch
* 1974-up engine
might be early B210. Specs are similar to other A12s, including the small valves
looks like a twee Datsun 1000 exhaust manifold?
Posted on: 2020/1/10 19:50
Texasmidget, the piston I couldnt see in TKs performanceforums post
but apparently he had the pics on aussiev8 forums.
Yet it is the usual Nascar combustion chamber design that is used on
everything these days prob originated from Larry Widmer or one of those
great Nascar engine builders. It seems to be the most popular chamber
design on all V8 engines and circletrack L4 both cross and non crossflow
pushrod heads. I guess with bigger bores on an A series such a small
chamber if using the A12 head would be fine with flat top pistons if
the cam is not too crazy where valve reliefs would be needed.
Posted on: 2020/1/11 2:22
