Browsing this Thread:   3 Anonymous Users
« 1 ... 12 13 14 (15) 16 17 18 ... 20 »
Re: wagon body work
From Sydney
Is it not an option to completely remove the dash for better access? From memory 4 bolts, 2 on top and 2 on the side underneath. [plus steering column 2 bolts]
Posted on: 2020/2/5 3:55
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: wagon body work
From melbourne
Unfortunately as suspected , the rust is also along the corner seam on the inside under the sill. Yes had to remove dash frame to have a closer look. Plus it gives me a good chance to sand blast and fill behind / between the sheets and down the pillar with wax to prevent further chances of rust. This I want done properly the 1st time.
I feel guilty about the cheaper option for the rear cargo floor , but the way it is done , I can easily and cheaply replace the the flat sheets with original ribbed floor when I find a donor wagon.
There,s about 450 hrs work done so far
Posted on: 2020/2/5 4:26
Re: wagon body work
From melbourne
What options do I have ??
I am in search of rear tailgate window rubber and rubbers for the side glass on cargo area.
There was a place in Oakleigh that did custom rubbers but long gone now.
Posted on: 2020/2/5 4:47
Re: wagon body work
From melbourne
The 3 holes arnt the issue , the seam on the right is soft when you push on it
jpg  237.jpg (67.93 KB)
14887_5e3a4acb2bd0f.jpg 540X960 px
Posted on: 2020/2/5 4:56
Re: wagon body work
From MOOROODUC. Victoria
Scott's old rubber. He now trades online including ebay
Posted on: 2020/2/5 10:29
Re: wagon body work
From melbourne
Thx Demacoz
Cut n welding inner wheel arch
And drilled the rear cargo plate ready to weld / tack on
Under the floor seems pretty good
Jades sanding down the dash frame because its out , so may aswell paint it.
jpg  239.jpg (62.80 KB)
14887_5e3b8cdd314ad.jpg 540X960 px
jpg  242.jpg (92.01 KB)
14887_5e3b8d0064ec4.jpg 720X960 px
jpg  238.jpg (121.31 KB)
14887_5e3b8d23b7d80.jpg 720X960 px
jpg  243.jpg (131.82 KB)
14887_5e3b8d3858b42.jpg 720X960 px
jpg  240.jpg (76.75 KB)
14887_5e3b8d57d2685.jpg 540X960 px
Posted on: 2020/2/6 3:52
Re: wagon body work
From melbourne
patch work done on side and end of wheel arch
just needs a bit of a grind and epoxy now
jpg  246.jpg (133.78 KB)
14887_5e3bc2a6036bd.jpg 720X960 px
jpg  247.jpg (123.38 KB)
14887_5e3bc2d1308b3.jpg 720X960 px
Posted on: 2020/2/6 7:39
Re: wagon body work
From melbourne
Not too much happening today
About to start on left side rear cargo floor
Decided to opt for the battery to be placed in the pocket and have 2 options.
Either way a the panel needs to be boxed out to fit 1 large battery or not as much
to fit 2 smaller and narrower battery's . Think will opt for 2 smaller so doesnt jut
out as much . Will need to get 2 lithium battery's for measurement first.
Question !!
I know ive had the insulation laid over the gearbox tunnel
Will my Dellows Celica box fit in or do I need to cut n split the tunnel ??
As I dont want to later on get a Auto tunnel.
jpg  209.jpg (51.54 KB)
14887_5e3ce7c6f1868.jpg 540X960 px
jpg  253.jpg (166.13 KB)
14887_5e3ce7e61f92b.jpg 720X960 px
jpg  251.jpg (125.10 KB)
14887_5e3ce7fae729d.jpg 720X960 px
Posted on: 2020/2/7 4:31
Re: wagon body work
Posted on: 2020/2/11 3:31
Edited by unfamilia on 2020/3/29 11:46:20
Re: wagon body work
From melbourne
Been a slow start to the week due to another small job that came in
Right side cargo floor done and now moving onto the left
Right side wheel arch done , dash tidied up
At the point whether to keep going or into storage .
jpg  259.jpg (129.68 KB)
14887_5e42b9e67c0ce.jpg 720X960 px
jpg  257.jpg (114.84 KB)
14887_5e42ba1894bbb.jpg 720X960 px
jpg  260.jpg (76.11 KB)
14887_5e42ba2ce08ea.jpg 540X960 px
jpg  261.jpg (126.70 KB)
14887_5e42ba3befdd4.jpg 720X960 px
Posted on: 2020/2/11 14:29
