Weber DCOE EFI Throttle body
Hi all,
Was about to order one of these off ebay, seem to be around the $350 mark here is Oz with fuel rail.
Who has had experience with these in a turbo set up? They claim to be sealed shafts and all, anything to look out for?
Posted on: 2020/3/15 10:42
Re: Weber DCOE EFI Throttle body
I doubt there would be anyone here but few use quad or twin throttle body
turbo efi on their A series engines. Seems a single TB is easier.
Which ones were you looking at?
Posted on: 2020/3/16 6:44
This
jpg  index.jpg (5.02 KB)
11959_5e70b8e0f4189.jpg 259X194 px
Posted on: 2020/3/17 11:47
like stated before better for NA and also take in
that if you fork out for 2 + manifold + plenum + linkages
then Matt MD_machine on instaglam :) offers a billet setup
made by him in the USA for 750usd.
Thats is cheap for something original and with the attention
he gives each item with your choice of cnc tattoo/insignia.
Posted on: 2020/3/18 4:42
From Little Rock, AR
More info on this billet efi intake for $750, please
Posted on: 2020/3/22 3:07
From Adelaide
I was planning on doing turbo and ITBs but the MSII ECU I have can't do it. I needed to use a mixed speed density/ alphaN (throttle position, engine speed) tuning method since the manifold vacuum is not useful above a certain throttle position with ITBs. AlphaN doesn't work with boost. If I could have an AlphaN region in the load table rather than a switch point line it may have been possible.
Short answer is check whatever ECU you're using can support ITBs and boost. The tuning may be a little tricky.
Posted on: 2020/3/22 20:41
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
hey AFRacer your side of the pond
Matt on:
Instagram @MD_Machine
Posted on: 2020/3/23 6:29
Is that the only way to get ahold of the guy? I don't have nor do Instagram...
Posted on: 2020/3/24 5:44
From Creswell, Oregon USA
Pretty sure I have a profile on here and my email is on just about every Datsun Forum ;)
Mattndew02@yahoo.com
Posted on: 2020/3/24 7:46
An idea doesn't work unless you do.
Parler @MDMachine
lucky Matt still does email unlike many businesses these days.
I prefer forums, private emailing (protonmail & tutanota) and blogs myself.
Strange that is considered oldschool nowdays vs criminal data stealing fakebook.
Posted on: 2020/3/24 9:16
