Brake lights always on
My rear brake lights are always on even when ignition is off. Brakes seem fine and fluid is topped up. Am I looking at an electrical fault?
Posted on: 2021/2/26 4:46
Re: Brake lights always on
I see the issue. A little plastic bump on the upper pedal has disintegrated so the switch fails to turn off.
Posted on: 2021/2/26 5:59
Part number is 46584-S0100 or 46512-H0101 according to the wiki.
Posted on: 2021/2/26 6:25
Edited by SunnyDaze on 2021/3/3 7:32:58
From MOOROODUC. Victoria
Yep. Common problem
Posted on: 2021/2/26 6:45
From Adelaide, SA
Did you find a genuine replacement? I got a mate to turn up a bit of nylon that fit in there and works a charm.
Posted on: 2021/3/2 4:22
Yes they are plentiful, for example on ebay. Seems the same part was used for many cars over decades.
Posted on: 2021/3/3 3:16
From Las Vegas USA
The one on my car recently failed.
Posted on: 2021/3/3 4:08
From Kelmscott Western Australia
Replace with a nut and bolt to suit
Be wasting time with genuine part as it will break with i. A year
Posted on: 2021/3/3 12:43
