1200 utes Unite!
Let's see some picks of current or past rides, or just renderings of cool cargo haulers!
jpg  Super Datto!.jpg (92.58 KB)
174_67c66085788d2.jpg 640X640 px
Posted on: 3/4 2:08
Re: 1200 utes Unite!
bluebird-style 1200 ute highway patrol with Datsun 510 grille and Supersonic crease line
jpg  blutora black-and-white.jpg (38.40 KB)
174_67cf11121b3c9.jpg 640X640 px
Posted on: 3/10 16:19
I am looking at swapping an A12 with an A15 in my 1200 ute. I will run twin SU carburettors with extractors. Any suggestions on what I can do to this engine to get the maximum out of it?
Will I have to have the cam ground for racing application? Productive comments will be appreciated.
Posted on: 3/26 6:52
Well it depends on what you want
A racing cam means high-rpm power. Do you rev your A12 up to 6000 rpm now? If you never do, you won't like a racing cam. With racing cam, you will shift higher than 6000 rpm, where the stock A15 makes peak power
I would skip the extractors. Use a cast iron extractor (factory GX-style exhaust manifold) is quieter and makes just as much power at 6800 rpm. Plus more durable, last longer. Long-tube xtractors are only better if you tune them for a specific RPM range. Some just like the sound of tubular extractors
The stock ute 4.11 rear diff is a great compromise between quick acceleration and fuel economy. But if you have taller than stock 12" tyres, I would go with a steeper diff like a 4.375 or 4.675 from a Vanette in order to regain some acceleration
The other way people get the most out of an A15 is to put higher gear diff like a 3.7 or 3.45, keep the exhaust stock and fit taller tyres. This way it will get the most fuel economy, but the A15 will still accelerate as well as the A12 while getting better highway fuel economy. But then better than all that is a 5-speed overdrive
What do you hope to get out of it?
Posted on: 3/27 8:17
From MOOROODUC. Victoria
I'LL Bite .... latest pic
jpg  Ute 2025.jpg (192.63 KB)
8710_67fa19d3b038f.jpg 756X756 px
Posted on: 4/12 8:44
i always thought that dark blue looked great with light color wheels. What are the model of the rims?
Posted on: 4/13 6:49
Performance Mag Wheels
jpg  Perfrpmqance Mags.jpg (100.10 KB)
8710_68089afd69858.jpg 439X414 px
Posted on: 4/23 8:47
From Las Vegas USA
So as someone whose run both an A15 and an A12 in their race car my advice would be stick with the A15. The stock bottom end on either motor will rev to 8600RPM without issue.
Do not run a race came; you'll end up with a motor that does nothing below 5000 RPMs
Beyond the SU's and extractors cleaning up the ports will get you around an 8% improvement. Larger valves will net another 6-8% depending on which size you use.
My mildly tuned A15 made 99hp at the wheels. The same spec in the with an A12 will be around 78-80whp.
Posted on: 4/24 21:18
From Las Vegas USA
I still want to build a Ute for vintage racing; just to be different.
Posted on: 4/24 21:19
From Brisbane, QLD
I’d love to see more B120/GB120 in the states without the played out Hakotora kit
Posted on: 4/26 13:13
71 B110
