« 1 (2) 3 »
Re: My Latest Race Viedeo
From Las Vegas USA
D,
Anything other than the A-series moves me into the faster class.
Posted on: 5/13 4:29
Darn it I see. How about Miata headed A13
166rwkws from B6 no porting just cams
Thats also an oval track combo that one
of out members Rob got on to showing us
how it is done some years ago.
The post 1998 B6z6 head has 125hp stock
@ 6500rpm with 9.4:1 compression so with
10.5:1 comp with 1300cc will need 8k rpm
but should get another 5-10hp along with
headers and better inlets like R1 carbs.
The ZL-VE head on the 1.5L that replaced
the B series engines uses same block but
heads are superior with VVT and even with
100cc less makes 130hp which so you only
need 7500rpm to make that.
Also comes with stainless 4-1 headers
Either way love the vids!
Posted on: 5/15 16:35
From Las Vegas USA
The two classes are C-Sedan and vintage GT-Lite.
C-sedan requires the A series under 1300CC
GT-Lite allows me to run any rule set from a major sanctioning body. In the case of the B6 head on the A14 block I'd be in the same class as if I simply installed an SR20DE. It would be far simpler and the car would be faster if I ran an SR20. Further while CAMS IPRA allows a turbo A12 the rules, for vintage GT-Lite rules say forced induction automatically put you into GTO. GTO is where the V8 cars are.
I could in theory attempt to petition the club to allow a turbo A12; based on previous conversations I doubt it would be successful.
If I want to win either class I need to put the time and money the class leaders do. That won't be happening because I find that level of effort sucks the fun out of it.
Posted on: 5/15 18:22
Definitely about fun first and foremost! Do the minis run twin cam heads?
Their boxes would suck to get so much metal from engine anyways... money pits.
If its just A series then there is a tried combo not many reveal as its oval
track again and japanese racing using repurposed A12 cranks that have damaged
mains then getting them destroked to 68mm + sleeved 78mm bores will allow
42mm inlets / 33mm exhausts with a mild grind 1298cc and R1 carbs will easily
make 130hp ate or 90+rwhp. You are doing it right anyway as its all about fun.
Posted on: 5/18 10:48
From Las Vegas USA
I appreciate.the kind words. We are having a ton of fun.
Posted on: 5/19 2:00
From Snohomish, WA USA
It does look like fun. 👍
I use to have one of those rear view mirros on my '76 B210. 🙂
Posted on: 5/19 15:17
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Not too shy to talk
Looks like fun. what size tire are you using? Looks like you are getting a bit squirmy mid corner causing a good bit of speed wash off. To take advantage of the lightness of your car with lower HP mid corner grip would be gold.
Posted on: 8/29 7:57
From Las Vegas USA
I run a 20.5 x 6.0-13 Hoosier vintage TD-R.
It's a bias ply tire so the car moves around a lot.
I have the car set up very loose. I four wheel drift the car heavily and that is what you are likely seeing.
I'm also carrying more corner speed then most other drivers.
Posted on: 8/30 2:06
That reminds me of a classic Top Gear episode: EVO vs STi
* The EVO was a remarkable bullet around the track, oozing speed and precision
* The STi was ungainly and wallowing
Then it was revealed that the Subie was faster around the track
Posted on: 8/30 4:43
From Las Vegas USA
Dave I've tried driving the 1200 in the same manner that I would one of my single seat cars on slicks (read what and tidy) and it ends up going about 2 seconds a lap slower.
Posted on: 9/6 2:13
« 1 (2) 3 »
