Weber DGAV Jet sizes for A15?
From Burbank, CA
Anyone know what size jets to use?
Posted on: 2004/7/19 18:51
Re: Weber DGAV Jet sizes for A15?
I posted the ones I used, but it only ran good, not dynoed or tested or anything.
other than that, I would start with the A12 jettings, see the 32/36 article in the tech section for the specific jets.
Posted on: 2004/7/20 2:27
From Burbank, CA
I saw those, I was wondering if those would be a good starting point for the A15. Overall it runs pretty good, Idle is a hit high still, i might be able to bring it down.
Posted on: 2004/7/20 3:21
From durban, south africa
is that the 38dgas carb?? if so don't stagger the jets eg:185 180 it wont work let me know if you are using that carb and i'll give you my specs on my A-14
cheers
nicholas
Posted on: 2004/7/20 13:33
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
From CHristchurch, New Zealand
SO did anyone find the jet sizes for an a15 with a 32/36?
Posted on: 2004/7/20 22:20
From Burbank, CA
i'll check and see if my carb supplier has any recommended sizes when i go out in a bit.
Posted on: 2004/7/20 23:56
From Burbank, CA
Well, there is no book of jet sizes per se. So I ordered the jets mentioned in the 32/36 dgav section, since they're probably a good start. I was told that there are no choke tubes ( whatever that means. I can't get them, and probably don't need em. )
Posted on: 2004/7/21 1:16
From Christchurch, New Zealand
Does the different sizing in 3.5 and 4.5 Choke tubes make much of a difference?
Posted on: 2004/7/21 1:20
1972 Datsun 1200 Coupe
Rosso Corsa Red
14" Watanabes
Twin 1.5" SUs to go on
Extractors w/ 2" exhaust and muffler
Sony Xplod Sounds featuring Active Black Panel, 4 Channel Amp, 4 way 6x9s & 12" Sub
From Burbank, CA
they probably matter less than the other tubes, since you don''t run on the choke much.
Posted on: 2004/7/21 1:27
From Burbank, CA
I have nearly all the jets now, the main jets were out of stock, so I have everything but those and the choke tube. I'll let you guys know how it goes.
Posted on: 2004/7/22 23:50
|||\ 81 KPB310 /|||
