radiators
From Wamboin near ACT(canberra)
What radiator should i use for an a15 in a 1200 ute. I have been told 2 use the sunny radiators. If this is true does anybody have one 4 sale??????
cheers
Posted on: 2004/8/11 22:11
Re: radiators
From Brisbane, Australia
I would suggest using an SR20 radiator, sure it may be a bit of mucking around now, but later on it will save time and have ample cooling capacity. I have used both a 120Y and Gemini radiator without drama's.
Posted on: 2004/8/11 23:26
Re: radiators
the sunny radiator is plenty big for that engine and is easy to install ... putting a larger one in will not have a benefit
Posted on: 2004/8/11 23:49
Re: radiators
From Birchip, VIc , Australia
tommy,
I used the sunny radiator in my ute for ages and it was perfect. The Temp gauge only just got over the C. It's very easy to install also, just needs to be bracketed off to one side and the other side can use the original mounting holes. You can pick them up from a wrecker or a reconditioning place for about $80.
However I was using it against my standard A14. Maybe the way to go is the SR20 radiator to give you a final solution and never having to change it again.
I think I might investigate the SR20 radiator also for mine to solve a minor heating issue since the motors been worked.
Cheers
Re: radiators
installing the gemini radiator this weekend (sunday hopefully)... it looks to be the best compromise between stockish and full scale radiiator swap (sr20 style) for minimal $$$. my $50 chemical claen testing and resealing looks trick.
Posted on: 2004/8/12 13:33
Re: radiators
so what do u guys recommend out of the sunny radiator and the gemini radiator???. I was thinkin bout goin 2 the wreckers 2 day, 2 get it
Posted on: 2004/8/12 22:44
Re: radiators
From Coondle, WA Australia
no this is gonna make some folk think...
my 1000 ute is going to recieve a bomber a15, and i know for a fact that the original radiator only just keeps up with my worked a12 in winter.
There is notmuch room in the engine bay for anything else, so i think that a custom job is the only answer, unless someone has had better experiences with other options.
Any ideas??
Posted on: 2004/8/13 0:23
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: radiators
This is what i have decided 2 do, i just went in before and bought a datsun 1500 ute radiator. Im goin 2 chuck a thermo fan on that and then put it with the a15 and see how it goes, If that doesnt work then i will move on 2 somethin a bit bigger
Posted on: 2004/8/13 5:20
Re: radiators
From Perth W.A
Go for a 1992 Pintara radiator they are thin but long and would probably be suffice for your application, pick one up with thermo fan and bobs your auntie...
Posted on: 2004/8/13 5:33
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: radiators
From Perth W.A
the hose ends are on the right sides and would be fine with a bit of pipe measuring. they keep a CA20 cool in a EW engine bay with the exhaust manifold 3" from it so they must be okay
Posted on: 2004/8/13 5:35
120y Coupe
