Browsing this Thread:
2 Anonymous Users
The Force |
Home away from home ![](http://datsun1200.com/uploads/rank49ca09456ba1d.gif)
Guys, I had the pleasure of catching up with Bart - alias A14 Force and checking out the progress of his supercharger conversion yesterday. I can assure you all that this car is a WEAPON and if it does'nt cut low 14's/high 13's through the quarter ( once he solves his traction problems- up in smoke in 2nd and showing signs of letting go in 3'rd!) I'd be extremely surprised. Lots of work and finishing off to be done but watch this space because once its fully sorted its going to more than raise a few eyebrows. Cheers Dave
Posted on: 2004/9/20 2:09
Re: The Force |
Just can't stay away ![](http://datsun1200.com/uploads/rank49ca09456b69e.gif)
From Birchip, VIc , Australia
I'd be very keen to find out how he is going too. I get my motor in around a fortnight and it is almost identical in makeup. I'm keen to compare times and traction issues once I start driving mine. Cheers, Stu.
Posted on: 2004/9/20 2:45
If you get a lemon, remember to ask for the tequila and salt!
Re: The Force |
DiscoStu, there is a niiice burnout pad out here u can test ur traction problems on hehehe, my_lil_beast and I tested a stok VR V6 como out there... the videos are awsum! ![](http://datsun1200.com/uploads/smil49ca0afcd5bbb.gif) hehe. cheers, woodydat.
Posted on: 2004/9/20 3:12
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed. Jk Rubicon unlimited, 58 CJ3B Willys
Re: The Force |
No life (a.k.a. DattoMaster) ![](http://datsun1200.com/uploads/rank49ca09456da4d.gif)
From Christchurch NZ
Cheers for the kudos Dave. It's really incouraging to get good feedback from people who know. I Gave Allan Taylor a drive of it tonight, (My eyesight at Night without my contact lens is a bit dicey) And he was well inpressed also. He said there is a street meet soon , so with a bit of preparation I'll hopefully get to find out my times.
Posted on: 2004/9/20 10:25
Forced Induction! Because everyone knows you don't bring a knife to a gunfight!
Re: The Force |
Bart, If you take it to that street meet for goodness sake take the 4.11 out of it first. I spoke to my engine builder last night and he was very much of the same opinion as far as your timing went- that is find out exactly what you are running and don't give it any more than 34degrees total! I expect to see some impressive times posted. Cheers Dave
Posted on: 2004/9/21 5:25
Re: The Force |
From Canberra, Australia
now that progress is acutally being made with my car, I would be interested in the mods that you had to do to get everything running with the charger. Apart from adding the charger and the manifold... What else did you have to do?
Posted on: 2004/9/21 6:26
1971 Datsun 1200 Coupe A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust. Standard 1200 4 speed with lightened fly wheel and HD clutch Stanza front struts and brakes. 15x6 CSA Wheels with 195/50 rubber.
Re: The Force |
I put a decomp shim under the head, had the head overhauled, (recut seats, bronze guides and a very light skim) Fitted some dual valvesprings, (shimmed to installed heights, to give 75-80 pounds of closing force) And had a cam pupose ground for force feeding. I asked for a cam that would make power to 8000. (If your gonna Build a rocket, why not go the whole hog?) When it was running just a hitachi carb it was too lumpy, and I was kicking myself. But with the blower on and a weber it has sweetened up a bit. Plus with the instant response the supercharger gives, It will pull strong even from below thw powerband. (It doesn't like going round corners slow in third gear though) I also disabled the power valve in the carb. I read about his in a book about holleys. Due to the vaccum coditions created by froce feeding, the powervalve never opens. The upshot of this is running slightly richer jets. (by the way, my jets were guessed, so I may try a richer secondary jet too aleiviate the pinging it experiences at full throttle.) Oh yeah, I just remebered, I put a pressre relief valve in the manifold. This is to vent off excess pressue in the event of a backfire. (backfires can do damage to superchargers.)
B110SSS, I will be taking out the 4.1:1 diff proir to running it down the strip. I just hope the welded up 3.9:1 H145 will be able to handle the grunt long enough to get me home, without snapping a carot.
Posted on: 2004/9/21 9:12
Re: The Force |
![Open in new window](http://datsun1200.com/modules/myalbum/photos/3476.jpg) For more pics see photos posted under my name.
Posted on: 2004/9/21 9:13
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
Re: The Force |
Thanks Blair. That day seems so long ago now. There is one pic of it under my profile too. (and one pic that didn't work)
Posted on: 2004/9/21 9:17
