(1) 2 3 »
Wanted: 6-speed for A12
Looking for 6-speed transmission for A-series engine.
Posted on: 2004/9/22 16:23
Re: Wanted: 6-speed for A12
From Newscastle, Australia
What???? cmon DD...really???
youd probably have to use a Honda s2000 transmission with a pretty special bellhousing made up ..I guess. The ZF 6spd in my Holden Gen3 powered wagon was huge and a clunker. All other 6 speeds that I can think of are FWD or Mid engine... or V8..
BTW I reckon a Honda S2000 driveline would be a really neat setup in a 1200.
Posted on: 2004/9/22 23:11
Dont die wondering.....
I don't know,..... David may well know something that we don't when it comes to this. Like most of us, I have never heard of a six speed for these engines, but that doesnt mean that they don't exist.
C'mon Dd, spill the beans, if these things actually exist, then what were they used in.
Actually, Dd knows a LOT of things that we don't.
Posted on: 2004/9/22 23:42
Love your Datsun.
Treat it well.
The 200sx has a decent box that would be small enough i reccon, but $$$Quote:
Posted on: 2004/9/23 0:17
From Sydney, Australia
200SX 6 speed is "kind of small". Depends if you are a "Shallow Hal" in regards to gearboxes.
The 200sx (S15) gearbox is quite a bit larger than the S13/S14 5 speed. It would weigh more than the A series engine.
Cheers,
Chris
Posted on: 2004/9/23 0:52
From Brisbane
Don't forget the MX-5 (Miata for those in the US), it has a six speed and is RWD. That said, you are still going to pay through the nose for one.
Posted on: 2004/9/23 1:39
Quite a regular
From Flinder View Qld
how about two 3 speed autos glued together...
Posted on: 2004/9/23 3:39
From Wellington New Zealand
The Caterham 7 uses a 6 speed. I think it's based on a quaife kit fitted to the Borg Warner type 75 gearbox as fitted to Ford Sierras. It would be relatively small. As for an A series box with 6 gears if you removed reverse there would probably be room to do it. I remember stories of "special " Mazda 6 speed boxes so maybe some one somewhere had a 6 speed Datto box built.
Posted on: 2004/9/23 4:27
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
From Perth Western Australia
that would give you a 9 speed...
but its been done before... some dude wanted to have the lower gears for drag racing, and still be able to cruise, so he put two gearboxes in rather than swap diff centres every time he went down the strip... looked kinda weird with two quickshifters next to eachother, but apparenltly it worked well. (it was in an old chevy or something... don't think it'd fit in a datto)
only downside was the extra weight
Posted on: 2004/9/23 6:07
From Perth
Lexus do a 6 speed behind their glorified camry too. RWD
No idea how big they are though
Posted on: 2004/9/23 11:30
(1) 2 3 »
