Skyline stumpy box problems
G'day guys.
I've recently got my 1200 running with the CA18 and skyline box. The problem is that the gearbox is terribly noisy. I did the bellhousing swap on my gearbox and have now got myself worried that I must have buggered something up. The noise is definitely gearbox, as it goes away when I push the clutch in. Also I have a new thrust bearing. It sounds like a gearbox bearing and it's whiny when it drives. I can handle it if there is just a stuffed bearing in the box but I was just wondering if there may have been something I missed while changing the bellhousings which may be causing this problem?
Posted on: 2004/9/30 14:22
Re: Skyline stumpy box problems
From Mudgee NSW Australia
Is it noisey in 4th??? did you have to change the clustershaft bearing when changing belhousing over???
Its probably just a mainshaft or clustershaft bearing not very $$$ to replace just a pain to stip down and press off.
A full rebuild- bearing kit is around the $400 mark.
I had a spare rebuilt box ive since sold it as I run the stocko S13 box
Posted on: 2004/10/1 11:11
If In doubt run more BOOST
I haven't had a change to use 4th gear yet as the car isn't registered and have only managed a few drives up and down the street. I didn't change any cluster bearing when I changed the bellhousing. That's what I'm worried about. Would the bellhousing still go on if I had the wrong bearing? I might just pull it out and take it to someone and see what they think... THis is killing me. I get it all together and the gbox is stuffed and the clutch is slipping. When you think no more could go wrong something does!
Posted on: 2004/10/2 7:20
From Little Rock, AR
If you're using a new clutch it's going to slip for a couple hundred miles!!! It takes about 500 miles to break in a new clutch sometimes!!! The 1200 NEVER slipped brand new or well used...but my 180SX slipped bad with a new clutch if you gave it gas. After about 2-3 weeks of easy driving it started gripping REALLY good and doesn't slip anymore!
Posted on: 2004/10/2 11:01
From Millgrove Vic OZ
If you surface the flywheel they usually wont slip if the clamp pressure is sufficient.
Posted on: 2004/10/4 12:48
Cheers Feral
I have bought another stumpy skyline box and CA20 bellhousing with the intention of putting another gearbox together for the car. When I went to put the CA20 bellhousing on the gearbox I noticed that one of the main end bearings is smaller than the hole in the bellhousing.
Do I have the wrong bellhousing?
Can I get another bearing pressed onto the shaft?
Can anyone give me a part number for this bearing?
Thanks
Posted on: 2005/1/11 0:06
From California
I just had my 5spd rebuilt, and it still has plenty of gear noise that goes away when you put the clutch in but then wines in 5th, so go figure
Posted on: 2005/3/14 9:19
There is a good chance that this is whats wrong with your other gearbox. If so, then the front of the cluster gear is unsupported.
Take your sample [small] bearing & a nice clean transmission case to a bearing supplier & tell him what you need & what it's for.
Should be no problem.
Come to think of it, have a look at the bearing on the front of the cluster of the CA gearbox. It might be just the sample you need, particularly if the I.D. is the same on both bearings.
Posted on: 2005/3/14 11:09
Love your Datsun.
Treat it well.
From Brisbane, Australia
Have a bit of a search in the web, but I "think" the bearing used is from a nissan Navara.
edit: A picture of your problem! A bearing flapping in the breeze.
Posted on: 2005/3/14 22:36
Not too shy to talk
From Narre Warren Vic
Pretty sure lagwagon has the part #.He's supposed to be giving it to me some time soon.
Posted on: 2005/3/15 10:18
