Big Power Mods
From Somewhere in OZ...
Hey guys,
I have been browsing the net for a few days now and can't seem to find some information I am looking for. I am starting to make plans for some more power mods in the near future and would like some
information on big power mods for a CA18DET. Do any of you know any sites or people I can ask in regards to my enquiries?
Also any info I can get on reducing tramp...
Posted on: 2004/10/31 5:14
Re: Big Power Mods
From Melbourne, Australia
silvia sites would be your best bet wouldn't they?
www.nissansilvia.com.au is a good forum i beleive
Posted on: 2004/10/31 5:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Big Power Mods
From Newscastle, Australia
Eliminate tramp by buying John Taylors from Pedders Penrith rear leaf set up. Ph 47312444
Posted on: 2004/10/31 6:28
Dont die wondering.....
Re: Big Power Mods
Are you getting commision? LOL
I should've though about him first.... And thanks rally... Didn't think.
Posted on: 2004/10/31 6:49
Re: Big Power Mods
From Mudgee NSW Australia
Hey nathan what kinda power are you after??? A rebuild with a good set of forgies Balance race preped rods and ARB bolts,bit of head work standard cams , Gt series turbo 20psi on pump fuel should see around the 200-220 rwkw.You will need bigger injectors a descent front mount ect. A bigger turbo will make more power but narrow the powerband quite a bit. A freind of mine has just made 260rwkw out of his CA18det. Has a set of hi lift cams and a pretty big turbo its pretty peeky not much under 5000rpm has run 11.5@121 in a mark 1 corty.
Cheers Andrew
Posted on: 2004/10/31 8:37
If In doubt run more BOOST
Re: Big Power Mods
From Sydney, Australia
www.silviansw.com
Both are pretty reasonable. Too many kids at www.nissansilvia.com.
We have talked about power and CA18's in the past. Most of the power in modern turbo motors are gained with a good rebuild/blueprint and headwork.
Too much more power, and the doors will become hard to close.
Up to you I suppose.
Posted on: 2004/10/31 8:38
Re: Big Power Mods
From Wollongong, NSW
you can check out the specs of the cortina at www.cortina-mk1.com.
very nice setup.
from what i remember his car already has a set of forgies, just a balance will go down fine. i would then opt for a decent size turbo, garrett gt25/30, and a custome exhasut manifold. then you have to upgrade injectors, exhaust, fuel pump/s etc.
... then you could go for one of those cool custom plenums i make (just giving myself a free plug).
Posted on: 2004/10/31 9:03
Re: Big Power Mods
I'll check those sites out... At the mo' my ute has 2 holley fuel pumps, surge tank, 13b Turbo injectors, GT28 (s15), front mount..mmmm cant think what else..
3" exhaust from turbo back...Quote:
Do you know what cams or where from?
Posted on: 2004/10/31 9:17
Re: Big Power Mods
Im pretty sure the cams are HKS. Im unsure on spec there are so many to choose from. Different valve springs had to be fitted The engine details -- CA18 engine specs
Posted on: 2004/10/31 10:51
Re: Big Power Mods
Thanks heaps again... I've actually tried looking for the HKS cams but could never find em...
Posted on: 2004/10/31 10:53
