32/36
Quite a regular
From South Africa
Hi dudes finally got my 32/36 she goes nicely!I havent opened her up yet to see what tipe of jets ive got in it splutters a bit and when u open the second barrel she eats tha juice so i just want to check what tipe of jetting was done, any ideas?
another thing my local carb shop said they only have F23 or F30 they dont have F66 emultion tubes any suggestions?Are there any timing issues i need to know about?
Thanks in advance
Posted on: 2004/11/1 10:12
Old Datsuns never die they just go faster
Re: 32/36
From Christchurch, New Zealand
They do not have F66!?!? Has anyone got a list of jets they use? I tried a 120 primary and it was too small. I forgot who it was but someone here gave their jet sizes from their dyno tune.
Posted on: 2004/11/1 10:21
1972 Datsun 1200 Coupe
Rosso Corsa Red
14" Watanabes
Twin 1.5" SUs to go on
Extractors w/ 2" exhaust and muffler
Sony Xplod Sounds featuring Active Black Panel, 4 Channel Amp, 4 way 6x9s & 12" Sub
Re: 32/36
Quite a regular
From South Africa
Air Correction: 175/145
Fuel: 120/145
Emulsion Tube: F66/F66
Choke Tube: 3.5/4.5
Idle: 50/55
Thats the one i used but like i said they dont have F66 emultion tubes?
Posted on: 2004/11/1 11:27
Re: 32/36
Suggested Weber 32/36 baseline jetting is in the 32/36 article.
Posted on: 2004/11/1 17:02
Re: 32/36
From Burbank, CA
I used some weird mix of the A12 settings there and the jets mine came with off of an MG...
I've been meaning to see what jetting they use on MG's because that would be ideal for out A15 engines.
I think I'm going to try the original jetting I had, Seemed like I had a bit more power. It made a sound going down the street that frightened pedestrians too ;)
Posted on: 2004/11/1 18:04
|||\ 81 KPB310 /|||
Re: 32/36
From Christchurch NZ
I think that 2L ford cortina carb has the emulsion tube you are after.
My supercharged A14 has the same "blup" sound when I dump the secondary. (Kind of like a rotary with mechanicalised secondarys) This is because there is no draft operated butterfly above the venturi. Std hitachi carbs have these, as the air speed through the secondary increases, it pulls the butterfly open. This helps maintain manifold vaccuum. As the webers' don't have it, when the big hole is opened, the engine momentariliy loses all manifold vaccuum, and it can't pull any fuel through. Thus the wee stumble as the motor suddenly gets too much air.
Still, it sound quite cool on my engine to have that wee blip, right before you get pushed hard back into the seat.
Posted on: 2004/11/2 8:17
Forced Induction!
Re: 32/36
From Burbank, CA
I think the idea is to not smash on the throttle. Mine seems to like continual gradual pressure.
Posted on: 2004/11/2 18:21
|||\ 81 KPB310 /|||
Re: 32/36
Remember that "great engineering" that Weber has? This is not supposed to happen. If a lowly Hitachi can be mashed to the floor without bogging down, the Weber should too.
The quick fix is to use a bigger accelerator pump. The correct fix is to carefully size, install and tune the Weber. Get the Weber book for details.
Posted on: 2004/11/3 2:09
Re: 32/36
From Perth, Australia
I had my 32/36 rejetted and it works a treat. The details of jet sizes are at :
Jet Sizes
Hope this helps
Posted on: 2004/11/3 4:21
1974 120Y Coupe
40 thou overbored A14
32/36 DGV Weber
5 Speed Gearbox
New Interior (in the making)
My website
Re: 32/36
BOOOOORING!
The throttle in my s/c car is ON, or OFF.
The in between is boring.
remeber, the 2L motor has a much higher airflow than a litle "A" motor, and the venturi is much bigger than a hitachi carb.
thus the air through the booster venturi is gonna be slower.
Posted on: 2004/11/3 7:52
Forced Induction!
