turbo hardware
i heard that the L20 is a turbo diesel engine and the L20B is a gas engine.am i right??
can i use the turbo hardware from the L20 disel for my L20B(like exaust manifold,intake manifold)??will everything fit??and if so can i upgrade the turbo on it.
i'm asking this because it will be easier for me.instead of fabricating my own
Posted on: 2004/11/1 21:07
Re: turbo hardware
From Burbank, CA
both L20 and L20b are gas engines. the B has a taller head.
Posted on: 2004/11/1 21:26
|||\ 81 KPB310 /|||
Re: turbo hardware
well then what is the turbo diesel engine that datsun made.and could i use the turbo hardware from that
Posted on: 2004/11/1 21:44
Re: turbo hardware
the L20b is a 4 cylinder 2 litre petrol motor.
the L20A is a 6 cylinder 2 litre petrol motor.
im not sure what the diesel L motor is.
Posted on: 2004/11/1 22:02
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
Re: turbo hardware
is there any parts that i can take from any engine that would make my project easier.for my turbocharged L20b.or i just have to fabricaite everything.
Posted on: 2004/11/1 22:15
Re: turbo hardware
Man go with the croud and CA it.
Posted on: 2004/11/1 22:29
Re: turbo hardware
From WA
it will be a job that requires everything to be fabricated from scratch - exhaust manifold, inlet plumbing, exhaust, carby adaptor etc etc.
there's no "easy" way to turbocharge a non-turbocharged engine, but there is an "easy" path to follow to remove most of the R&D involved.
Posted on: 2004/11/1 23:21
Re: turbo hardware
what is the R&D??????????????
Posted on: 2004/11/2 0:01
Re: turbo hardware
From sutho shire, NSW, AUS
research and development i recon
Posted on: 2004/11/2 0:19
Re: turbo hardware
From Brisbane, Australia
There is a turbo diesel 4cyl L series, designated LD20T. Only thing I know of that it is fitted to is the Nissan Largo people mover thing. I am told the manifolds will fit the L20B. They won't be anything flash, and may not flow very well for a petrol engine. But if that engine is available in your part of the world then it is worth checking out, but the turbo will have to be upgraded to be suitable for the wider operating range of the petrol engine.
Posted on: 2004/11/2 0:49
(1) 2 3 4 »
