D wrote:
I just think that althought the BW diff is easy and economical the LSD is pretty crap and clunky compared to say a hilux lsd or even a mazda lsd. Im not the only only who thinks these lsds are a waste of money and time so consider other options if you can you have been warned.
Not all LSD are the same in quality and the BW is on the bottom of the pile.
Although can handle some punishment they arent a performance LSD after all they are a BW.
mazda LSD = way overpriced and prone to excessive wear on even a std rotary. not very well suited to even a moderately powered vehicle. significant mods are required to make them last even a season in track cars.
i know. i speak from experience here.
hilux LSD = friction plates don't have enough surface area and are prone to slip with shock loading - splines on the 'plates' have been known to bend too.
BW LSD = great compromise between size, weight and tractability. almost a viscious type LSD in the way it feels when driving, except BOTH wheels spin
if you have IRS, the Subaru's are a nice tight LSD inside their R160.
if you want an LSD that "doesn't" slip, then a detroit locker is your only option - and not everyone likes that "locked-now-unlocked-now-locked" nature of them.
