« 1 (2) 3 »
Re: thermostat
From Brisbane
Anyone ever thought it might be these very hot days we are having on the East coast of Aus. heating up everyones engines,
I know my temp gauge has gone up a bit this last week. I'm not concerned though it goes up every year in summer and comes back to "normal" when it cools down.
I agree with pro-240c always run a thermostat
Posted on: 2004/12/1 8:51
Re: thermostat
From WA
it is getting undriveable? as in it starts to chug? how hot does it get? when did it start?
if not, check your temp sender isn't rooted, or you don't have an earth leak / dodgy earth from the dashboard.
if it is, are you using water or coolant? is ther enough fluid in the cooling system? have you got a fan hooked up (thermo or factory)? if thermo, is it too small? a single 10in flows less than the factory fan, and a single 16in flows as much as 3x 10in's.
sorry for the dumb questions, but we have to start at the beginning.
Posted on: 2004/12/1 8:54
Re: thermostat
From Wamboin near ACT(canberra)
Its driveable just abit scary when the temp guage starts sittin on H!!!. It was sittin under halfway last week. Now this week its went all weird and just shoot up. The engine definately feels like its runnin extremly hot 2, way hotter than last week.I definetaly dont have an earth leak, as it was earthed professionally. Im using coolant. There is enough fluid in the cooling system, and an overflow bottle is been used. I am running a 10in thermo and the factory fan!!!. Its just started 2 get really hot over the last week!!!. Im stumped!!!. I thought that the thermo and factory fan would be sufficent enough??
Posted on: 2004/12/1 9:52
Re: thermostat
From Christchurch. NZ
try and get a shroud for the fan so it will perform at its best or fit an electric fan, that way you get the most air pumped 'through' the radiator. If everything is fine, thats the only suggestion I can offer
Posted on: 2004/12/2 4:24
Re: thermostat
From Brisbane, Australia
Space the back of the bonnet up 5mm and remove the rubber sealing strip on the firewall. That should be good for 5 degrees.
You might wanna put and aftermaket temp gauge on it, just in case the factory units if up the creek, this happens more than I care to remember. Even temporarily. This will eliminat sender and gauge.
Posted on: 2004/12/2 5:14
Re: thermostat
pro-240c wrote:
now, take your thermostat out and you lose the ability for it to 'pressurise' the water in the block against all the surfaces it has to cool.
Ummmm....... not quite.
Cars ran unpressurised cooling systems without problems for over half a century & many of these cars are still happily driving around.
The boiling point of water is raised by about 3 degrees F for every 1psi that pressure is raised above standard atmospheric at sea level. With the increase in engine efficiency that came about with the introduction of "super" grade fuels in the 50's it became obvious that operating temperatures from 180 to about 195 degrees F were going to be the norm. This was too close to the boiling point of unpressurised water [212 deg. f] so pressurising the cooling system at even 7psi was enough to raise it to 233 degrees which was a good enough margin. This also stabilised the situation at high altitude where the boiling point would be lowered if unpressurised.
The ability of heat to transfer to the coolant is not significantly [if at all] affected by pressure in the cooling system. The only way to aerate the coolant is to introduce air into the water pump which will mix it into the coolant, particularly at high rotational speeds.
If car makers could save 5 cents on each new car by leaving out the thermostat while still being able to provide satisfactory performance & engine life, then there would not be a factory thermostat in the country.
Spend the few dollars that it takes & buy a new one, & while you are at it, give the whole cooling system a proper reverse flush & get rid of the rubbish in there, particularly in the radiator.
Posted on: 2004/12/2 7:15
Love your Datsun.
Treat it well.
Re: thermostat
From WA
beg your pardon?
i'm not talking about heat TRANSFER here, i'm talking about the ability of the coolant to stay as coolant and cool, like it's supposed to. if the coolant boils, it aerates and loses it's ability to cool.
when coolant boils, it releases oxygen yes? is oxygen in the cooling system now -not- an aerated cooling system?
you said yourself that
therefore if the thermostat is slowing the coolant flow, holding the coolant back AND PROVIDING PRESSURE (however insignificant), then surely the PRESSURISED coolant will be able to hold more heat...? yes?!
we can all argue what it's intentions are meant in a factory application, but there is only evidence of what it actually does which is what i'm basing my argument on.
Posted on: 2004/12/2 7:51
Re: thermostat
From Castro Valley,CA USA
If you'd like I could wander out to the assembly line tomorrow at work and see if the 2005 Tacoma's and Corolla's have thermostats.
I'm pretty sure they do.
Posted on: 2004/12/2 7:59
Re: thermostat
Oxygen is released when the water is boiling & by this time, the presence of oxygen as a free gas is really accademic. The visible bubbles in boiling water are normally steam, which are created at the point where the heat is high enough. Interestingly enough, the conversion of water to steam absorbes a great deal of heat & is a surprisingly good, if unpractical, method of cooling. The Rolls Royce Goshawk aircraft engine was to be steam cooled, but it was not a practical design.
The amount of pressure in the cylinder block behind a partially opened thermostat is not sufficient to be an issue as the pump is not a positive displacement type & the pressure is usually kept very low by the by-pass that recycles coolant from the head directly back to the water pump, by-passing the radiator. Coolant under pressure does not hold more heat than unpressurised coolant. It just holds higher temperatures before boiling.
Posted on: 2004/12/2 8:16
Love your Datsun.
Treat it well.
Re: thermostat
From WA
ahhh i'm not getting into this here - i understand where you're coming from Dodgeman, but i think there's more to it than that.
we'll agree to disagree and leave it at that
Posted on: 2004/12/2 8:49
« 1 (2) 3 »
