Front guard clearance issues
From Melbourne, Aus
I'm having trouble getting front guard clearance on my 1200 coupe. I'm running stanza struts (not lowered yet), with a little bit of camber (adjustable lower control arms). Tyre size is 13x205x60.
If I lower the car and add a bit more camber, it looks like it will make the problem worse.
Has anyone got any thoughts on a fix for this problem?
cheers
Bruce
Posted on: 2005/2/3 22:56
Re: Front guard clearance issues
From Perth
You don't want to know what I did....and I have 205/60/15is
Let's just say it involved removing quite a lot of metal
Where are the clearance issues...I am assuming it's at the top?
Posted on: 2005/2/3 23:03
From Melbourne, Aus
clearance at the top and the front
Posted on: 2005/2/3 23:13
From Perth
Can you wind off some of the castor? Do you have adjustable Radius rods?
At the top is a little more difficult, unless you want to run more camber, and use adjustable strut tops....but that's no good if it's a daily driver.
Posted on: 2005/2/3 23:47
From Brisbane, Australia
ahhhh! No!
this is normal for a 1200 with big tyres. cut some material off the front of the gaurd opening. A jigsaw (with a bit of race tape on the base to protect the paintwork) will do a much neater job than tin snips.
And you will have to lip the gaurd and pump it a bit to fit a 205/60 under there. Get the hammers, levers, and blocks of wood out!
Posted on: 2005/2/4 1:51
Then again, doing a little homework first, & fitting the right tyres would have precluded the problem in the first place, saveed you a few dollars, & prevented the need to butcher a poor unsupectring little Datsun.
Posted on: 2005/2/4 2:03
Love your Datsun.
Treat it well.
