pinging at high rpm??
From durban, south africa
hey guys at high rpm under boost the motor pings, i've checked timing it's a bit better but still pings
please help before it's too late
Posted on: 2005/2/17 10:23
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: pinging at high rpm??
This can be addressed in a number of ways.
1. Retard the timing when at high rpm & high boost by using a "boost retard" distributor
2. Increase the octane rating of the fuel
3. Lower the maximum boost pressure.
4. Reduce the maximum rpm level
5. Reduce the compression ratio
6. Use water-Alcohol injection when at high boost & high rpm
7. Richen up when at high boost.
8. A combination of two or more of the above.
I suggest the first one for best results.
Posted on: 2005/2/17 10:39
Love your Datsun.
Treat it well.
it's a e15 turbo motor stock standard apart from the air filter the book recons set the timing to 15 i've set it to 10 and it still pings using 97 octane?? why doesn't the knock sensor sort the timing out?
Posted on: 2005/2/17 10:47
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
Is it working? Have you tested it, or had it checked out?
Posted on: 2005/2/17 10:51
Love your Datsun.
Treat it well.
From Christchurch NZ
When it's rattling, BACK OFF!!!!!!!
Otherwise it will be a death rattle.
Posted on: 2005/2/18 6:03
Forced Induction!
From Melbourne Vic
knock sensors are fairly useless in their operation, they don't tend to do anything in the high rev range as its so noisy its hard to determine any knocking. thats when you most need them! are you sure its pinging? coz a factory turbocharged motor running basically a standard setup should not have a problem, especially if running 97 ron fuel (which i've never heard of). optimax, BP ultimate and i think mobil synergy are 98 RON, all other premium unleaded i believe is 95.
Posted on: 2005/2/18 6:37
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Melbourne Vic
oh.... south africa.... fuel is probably different. my bad
Posted on: 2005/2/18 6:40
yeh here we get 95 unleaded and 97 leaded.
i ran the ecu test last night and it said that the throttle control valve was faulty, where is that and what does it do? i retarded the timing only pings when you abuse it, but people said it might be fuel we are using
Posted on: 2005/2/18 7:41
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
From Melbourne Vic
i'm not certain on the e15, but on the CA18, to set the base timing you need to follow a series of steps including disconnecting your throttle postion sensor. you'll need a manual to know for sure how to do this, should be on the net somewhere...
Posted on: 2005/2/18 8:05
