axle tramp -solutions?
From Port Kennedy, Perth Western Australia
Hi all,
my ute suffers bad with axle tramp, does anyone use some kind of tramp bars/rods?
I thought of making a set similar to the early GT fords- brackets welded to the top of the axle tubes , pivot point on either chassis rail and a spring steel bar bushed at either end, bolted between the the chassis pionts and brackets on top of axle tubes.
The problem here is the ute fuel tank is in the way.
The other options are the old style tramp bars which bolt underneath the leaf springs , you know the chrome ones with the rubber stoppers that hit the underside of the chassis to stop tramp.- again the problem with these is ground clearance- mainly kerbs and shopping centre speed humps.
Anyone have any other suggestions?
Posted on: 2005/3/5 11:23
Re: axle tramp -solutions?
From sydney
my Kb10 had severe axle tramp, if you booted it it was undriveable, it now has a thick extra leaf on top of the other springs that only goes from the axle forward and stops the tramp really well.
Posted on: 2005/3/5 11:41
From Okinawa, Japan
My ute's got the second leaf reversed on top of the pack. (previous owner) No axle tramp problems, plus it lowers it. Stiff as hell and from memory not legal in Australia but it's fine here.
Posted on: 2005/3/5 12:22
Saw another idea with a bracket welded to the top of the diff housing and a bracket welded under one of the ute tray supports with a bushed bar between- had started to twist the tray support- not a good idea!
Posted on: 2005/3/6 12:34
From ACT
http://www.mcdonaldbrosracing.com.au/4link.php
the 2 link kit at the bottom of the page looks the goods. i am probably going to use this kit if i ever get around to doing an engine conversion
Posted on: 2005/3/6 12:36
Not a bad idea
Will have to see if i can work it around the fuel tank.
Posted on: 2005/3/6 13:03
From Brisbane, Australia
with a worked A series like you have, there is absolutely no need for additional links. Its overkill, and besides it's just treating the symptom rather than the problem. If your shocks are in good condition and your springs are done properly, you will not have axle tramp problems.
I assume you have lowered the ute? how?
Posted on: 2005/3/6 23:51
From newcastle, NSW
I presume that its a standard ute,A12?
Personally, i've never had a problem with wheel tramp in my 1200 ute, it chews 13' 65-205 tyres quite easliy!!!!!
My coupe does!!!! badly!!!!!!!(Only because its CA18DET POWERED!!!!!)
I agree with L18_B110, check your springs and shocks, you might find that it needs new shocks, on a ute that is easy, 2 bolts on each side, done in 15 minutes!
try that first.
depends on if you lowered it and how you did it.
Is that a 'CALTRAK' set up in the photo??
looks like it.
Posted on: 2005/3/7 0:37
Ok, Its a '72 lowered ute ( blocks welded under the diff/spring mounts) with a worked A14 running 195/60R14's. The current diff is cactis and I'm currently working on a replacement. The springs are a little warn , might sorce some replacements first, thanks guys.
Posted on: 2005/3/7 1:05
From Brisbane
looks like i have fixed my axle tramp problem, reversed 120y main spring cut down on top as a helper spring, today is the first time i have heard tyre squeel, not axle tramping, i have my koni's set to full soft.
Posted on: 2006/10/7 7:48
