Browsing this Thread:   3 Anonymous Users
Brembo Brakes???
Quite a regular
From New Zealand Invercargill
Hey guys just wanting to know how would i go about fitting some brembo disc & calipers to a 1200 coupe? would any bolt straight up like say silvia brakes
i'm abit puzzled on this so help would be good
Cheers
Posted on: 2005/3/8 4:25
Re: Brembo Brakes???
From Sydney, Australia
You might get lucky by using stanza (A10) lower arms, with Skyline R31 struts and some Brembo discs/calipers from a R33 Skyline.
Its not easy, and the expense involved in getting it wrong is to high for me to consider.
It's not worth it either. Only good for a slight increase in "pimp" status.
Posted on: 2005/3/8 4:44
From Adelaide, South Australia
the best bet is to use a datsport strut.
they do a number of different combnations the best one has a coilover strut with 4 pot r32 gts-t calipers and 296mm ebc rotors.
they cost about $2950.
i thing brembos would be a bit over the top
you can see them more at www.datsport.com
datsport is in Adelaide and i know you are in new zealand so doing this could be a bit to hard,just an idea
Posted on: 2005/3/8 6:05
Quite a regular
Cheers for your help guys, only reason for sum brembo's is tht i'm building my coupe up from scratch and want every thing done right and perfectly
Posted on: 2005/3/9 11:22
From Brisbane
Also Errol does a great setup, check it out.
http://www.datrats.com.au/BRAKES.html
Posted on: 2005/3/9 11:27
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
brembos are much more than perfect.
It's overkill. Unless you plan on going down a steep 300km hill while carrying 2 rhinos and 2 baby elephants and a wild boar in your datto.
Remember there are many dimensions to brake selection:
1. Initial Cost
2. Stopping Performance
3. Ongoing costs for consumables
4. Looks
5. Fit for wheel clearance
6. Unsprung weight vs. ride comfort.
Everything done perfect would empty a billionaire's bank account. Get a budget, divide up the expenses, and get the project finished!
Talk to a fellow NZ racer, and follow their suggestions.
Cheers.
Posted on: 2005/3/9 11:32
Quite a regular
Don't be silly dattodude you can't fit a rhino in a 1200 coupe let alone a wild boar, also just like to add that i was offered a set of brembo's off a subaru wrx at a real good price and an idea just came into my head but cheers any way.
Posted on: 2005/3/10 9:47
From sydney
If your getting the Brembos at a really good price maybe it isnt such a bad idea to try,you will have something nobody else has.
Will the wheels you want fit over the Brembos?
I have heard of Subaru Leone discs on a 1000 coupe so it could be possible.
It could involve a fair bit of stuffing about and you would have to fabricate some brackets for the caliper, but if you know someone cluey and good on a lathe, its worth a try.
anything can be done if you put your mind to it.
Posted on: 2005/3/10 21:38
