crankcase ventalation question
i have a 78 b210gx with the a14 engine. is it mandatory to hook the valve cover breather hose to the air cleaner or can i just put a breather on it? thanx in advance
chris
Posted on: 2005/4/27 21:18
Re: crankcase ventalation question
From Burbank, CA
the smog police would like you to burn the crank case vapor.
performance wise it won't matter much, though not putting the vapor through your intake will keep things cleaner
Posted on: 2005/4/27 21:28
|||\ 81 KPB310 /|||
From Central Vic
Ive always like to use a PVC setup because of the oily fums tend to leave smears on everythinig I run mine to a catch can then from the catch can to the intake this gives me best of both i belive
Posted on: 2005/4/28 2:06
From Christchurch. NZ
use it if you can, it will flush corrosive fumes from your crankcase, help keep you oil cleaner for longer, and lessen any horrible oil/fuel smells
Posted on: 2005/4/28 9:11
From Perth
What do people do with the crank vent on the passengers rear of the block ?
One of my cars has it blocked off..... the other doesn't.
Wondering which way I should go on the racecar. I currently run a pipe from the block breather to the rocker and then to the catch can.
Posted on: 2005/4/28 12:16
block it of, or vent it to your catch can as well
Posted on: 2005/4/28 12:24
Being a racecar I would say you want it open as much as posible. The conditions the engine is under, will be seeing more blowby than a street engine.
Posted on: 2005/4/28 14:43
From Central Vic
DONT BLOCK IT OFF
with all the blow by when you rev them up you will just blow out crank seals
Posted on: 2005/4/28 16:41
