1200 info
From Bridgetown, Barbados. W.I
I'm selling all my ford stuff and going back datsun ..i'm buyin a 1200 so jus need a littel info please.
1) from leaf spring to leaf spring,whats the distance??
2) Got an engine from a Vanette today.What could it be???(the markings seem to be missing)
3) Are the vanette(short) boxes any good??
4)How far out will a vanette rear end be on a 1200 datsun.
thanks for the help.
Posted on: 2005/6/12 1:51
Life's better SIDEWAYS!!
Re: 1200 info
Anyone??? i reall need this info.
Posted on: 2005/6/12 14:33
Re: 1200 info
From Adelaide, South Australia
On a ute the leafs are 103cms apart outside to outside.
Posted on: 2005/6/12 15:22
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
Re: 1200 info
ok thanks...i'm planning on using a 5.1:1 or 5.3:1 rear end on the 1200. I think it should fit with those measurements...its 50" from drum to drum.
Might have to use a Solid 2' spacer wid long wheel studs tho.
Posted on: 2005/6/12 16:36
Re: 1200 info
From Sydney, Australia
vanette Engine is probably an A series. Most likely A14 or A15.
Vanette boxes have a strange shifter section, as they are all column shift. Basically the same gearset tough.
Posted on: 2005/6/12 19:22
Re: 1200 info
well dismantled the engine 2day appears to be an A12 but has an A15head . So might jus fit a L16 or L20b engine in it now.
ps.can a L16 sump fit unto a L20b block. Cause the l20b came from a 200b and has the pickup in the middle.
Posted on: 2005/6/13 0:02
Re: 1200 info
From SA the place to boost
Yeah the L16 sump fits. You also need the L16 oil pick up.
Posted on: 2005/6/13 1:48
Stanza L20 Turbo
Bluebird Series 1 FJ20ET
Bluebird Series 3 TRX CA18DET
Re: 1200 info
From Perth Western Australia
sure its not an L18?? Most (if not all) L20b's came with the forward sump, while the L18's came with the mid sump....
my website in case you haven't seen it yet:
info on L series into 1200
might find some useful info there
Posted on: 2005/6/13 6:44
