« 1 (2) 3 4 »
Re: To spool or not to spool
From sutho shire, NSW, AUS
DVLDAT, are you serious that mini spools are heaps less harsh on your axels? i thought it just did exactly the same as a welded one but with no chance of splatter getting onto unwanted areas.
yes i have the 28 spline one......please explain more about this minispool not being so harsh on the axels cos i dont wanna break my custom axels there to expensive. haha
Elliott
Posted on: 2005/6/28 7:20
From sutho shire
if u have custom axels they should hold the power easy
mini spool's i was told give unlike the MIG locker, pending on what make as they have pinions in side which alow play forwards and backwards so when u turn it doesnt chew your tyre out,
correct me if i am wrong i was told that.
Posted on: 2005/6/28 8:00
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
By custom axels i mean shortened, not billet steel or anything too fancy.
Can someone please verify this cos if true i'm 100% on the mini-spool.
thanks
Posted on: 2005/6/28 8:19
mini spool is exactly like a welded centre.
It is a solid piece of metal that replaces the small gears in the diff. The axles go straight into it and are forced to turn at the same time. If a mini spool has play in it, the pin that holds it in place is very worn and will eventually fail.
For the price of a minispool, you might aswell weld the centre and be done with it. A mini spool is only really good for people like 1200rc that cant weld properly
Posted on: 2005/6/28 8:37
From Melbourne, Australia
id prefer open on the road, locked is awesome for drag/drift, extra traction and holding huge angles was easy
but for driving to work everyday and down the shops, welded is just plain annoying
all the usual comments are true
horrible noises
skipping/bouncing round corners
hard to reverse
its actually really hard to push the car too, specially around any sorta corner
never noticed any worse understeer though
Posted on: 2005/6/28 8:40
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney
Here is a quick description from the web on Spools and Minispools..
Spools & Mini Spools:
For racing, serious off-road, or crazy hot-rodders, a spool is the ultimate traction differential. Actually, it can hardly be called a differential because it does not differentiate. Spools have several purposes. First, they lock both left and right axles solid together so that there can be no loss of power due one wheel spinning faster than the other. Second, they usually support the ring gear much better than most other differentials. Last, they can be lighter than a differential, which saves rotating mass as well as un-sprung weight that the suspension has to contain.
The main shortcoming of spools is the fact that the outside wheel has to turn faster when negotiating a turn if both wheels are to maintain traction. If the axles are locked together, one or both wheels have to slip in order for the outside wheel to travel farther than the inside wheel. This can cause the rear of the vehicle to spin out, fish-tale, or can cause a lot of noise that sounds like positraction clutch chatter as the axles twist and release. Sometimes these effects are not all that bad, and they are less severe when 35-spline or larger axles are used. For those people on a budget, there are mini-spools available for many rearend designs. A mini-spool fits inside the standard open carrier, replacing the spider gears, and locking the left and right axle shafts together just like a spool does. A mini spool drives exactly like a full spool does, but they are not as strong as a full spool and do not add any extra support to the ring gear like a spool does.
Full article on description of different types of differentials can be found here.
cheers
Benny
Posted on: 2005/6/28 8:42
From sydney
1200rc r u serious there not that bad mate i dont no bout u but id rather put up with those tiny little things which realy dont bother me one bit then put up with a car that spins 1st to 4th with 1 wheel.
I found the open wheeler in my utes very dangerous as it would be spinning 1 wheel then hit third and all of a sudden cut 2 wheels and turn toward the cutter.
Posted on: 2005/6/28 8:53
personal choice thats how i felt, i like my car to be nice, i hated the welded centre from the first time i reversed it outta the shed
but loved drifting with it, at the end of the day it was my road car though
Posted on: 2005/6/28 9:01
1200 Coupe Rallycar
From sutho shire
im with NIS15L at least u can predict whats gona happen with locker open sux with boost,
also benifits of spool is that if u break a axel u only have 2 change one axel not both and centre as if u welded it all up all would have 2 be changed.
so will work out cheaper in long run
Posted on: 2005/6/28 9:28
Team New skool
From sydney
Why would you need to replace both axles if only one was broken,surely its the same no matter what diff set up you have.
Posted on: 2005/6/28 9:33
« 1 (2) 3 4 »
