clutch grabing??????????
From south australia
i got my a14 in and running now i have a different worry
my clutch is not engaging properly
and the tighter i adjust the cable the wors it gets what is wrong here???????
it grinds real bad trying to select reverse
and forward gearas are clunky
the clutch and presure plate are brand new and only did about 300kms behind the a12 and i am also using the same thrust bearing, flywheel and gear box its got me stumped! does any one else have any idea what is going on here????
Posted on: 2005/7/8 12:29
Re: clutch grabing??????????
From gold coast QLD australia
My only thought is the clutch plate is in back to front???
Posted on: 2005/7/8 14:09
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
From Adelaide, South Australia
Are you using a different box ?
Posted on: 2005/7/8 19:12
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
same gearbox
the clutch is in wid the shaft poking outwards
Posted on: 2005/7/9 2:28
i have just puled the clutch and gear box out and can find nothing rong
the clutch arm is puling in more than enough the presure plate all the fingers are nice and even and as for the cluthc plate being on the right way well it only goes on one way si i ruled that out .
he only thing i can think of at this stage is the air is damp here at the moment and when i had it all out to fit the a14 the damp air might have made the clutch plate swell
so i will put it back togeather and drive it around for a while and see if it comes good if not i might have tofgrab a new clutch kit
Posted on: 2005/7/9 4:49
From Christchurch. NZ
Check for cracks in the release fork or wear on the pivot, also check the spigot bush, and that the clutch moves freely on the spline
Posted on: 2005/7/9 6:50
From Christchurch NZ
Did you change the clutch cable?
In the past, when building a datto, I have grabbed a b310 clutch cable by mistake. (Probably cos it looked newer) Only to find that it was longer, and the clutch wouldn't disengage.
The other thing it miight be, Is, are you using a flywheel that is too thick?
I have seen big heavy flywheels, Out of like c20 vans. (which use a different bell housing) that take up so much room in a standard bellhousing that the fork can't make the pressure plate throw out.
Posted on: 2005/7/9 7:23
Forced Induction!
i am using all the same parts as was behind my a12
the flywheel is lightend so it should not be to thick i have a brand new spigit bearing
its all in good order the clutch arm has plenty of movement so i think it has somthing to do with the clutch and presure plate
Posted on: 2005/7/9 10:22
The description is giving mixed messages.
Tightening the clutch cable will put more pressure on the clutch fork, therefore making the clutch easier to slip.
But the description of the gears making noise tells me the clutch isnt releaseing completely.
Posted on: 2005/7/9 10:38
well when i had it apart i noticed that the fingers on the presure plate have hit the clutch plate from when i had it adjusted as tight as it would go so that is defanetly working but yes the clutch is still not releasing
Posted on: 2005/7/10 6:09
