Thanks for that, it probably explains why it is running bad now as well. It feels like it did before I adjusted the timing.
Now to find a replacement!
Don't worry about a replacement for the electrical switch in the picture.
Just hook the distributor vacuum line directly to the port on the carb. Use a plain hose, if there are any round fittings in the hose, remove those or use a longer one-piece hose.
This will bypass the "spark timing control" system, the main part of which is the solenoid on the front of the manifold in this picture:
engineThe 1972 Datsun 1200 (north america) has the same/similar solenoid called the "vacuum cutting valve solenoid". It controls the vacuum advance line, it prevents it from advancing under certain conditions. It's for emissions controls and not great for performance. It's like disconnecting the vacuum advance.
However, if the solenoid is "off", like the wires are disconnected, then it's all OK. Then it can't affect the vacuum advance, so no worries.
That is, if that's what that temp-switch controls. Older models used a thermo-vacuum switch in the same location (but you have an electro-switch there).
