Best way to get the rear end of my ute closer to the ground?
Hey all,
I want to get my ute looking pretty low when i get my new rims (They will be 16") It's lowered a bit now (Just the leafs adjusted) But i want to get it lower.
I've heard the best way is to flatten the leafs and fit lowering blocks?
How should i go about getting my ute alot lower?
Thanks in advance, Mike.
Posted on: 2005/8/7 13:39
Re: Best way to get the rear end of my ute closer to the ground?
From Sydney, Australia
I have some cheap lowering blocks for sale, here is the link...
lowering blocks and Ubolts link
James.
Posted on: 2005/8/7 14:02
Datsun nerd
From Melbourne, Australia
Heat up the springs with a blowtorch and get your 3 fattest mates to jump on the back.
Posted on: 2005/8/7 14:06
From Bris-Vegas
What the?..... What sort of advice is that? What you are saying basically amounts to sending him out to buy a new set of springs, as his will be stuffed within 6 months if he does what you suggest.
Posted on: 2005/8/7 23:22
CA18DET '74 1200 ute project
From sydney australia
he was joking,obviously because of the smily face at the end.besides,heating the springs only works on coils,so use this on the front.
Posted on: 2005/8/8 2:48
From sutho shire
get your springs reset (FLAT) then use 1'' lowering blocks or 2'' if u want the low rider look
Posted on: 2005/8/8 8:17
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
From Sunnybank, Brisbane
seen a few guys turn there springs over completely, not too sure how safe or smooth it would be but ive seen it done
Posted on: 2005/8/8 11:14
From Christchurch. NZ
Well you could do the same as what I did. Take the long overrider and turn it upside down and fit it on top, also flip the second spring. Will stiffen the rear end nicely about 20mm from original bump stops.
Will look about this high, thats running 15" rims and 185/55 x 15 on the rear
Posted on: 2005/8/8 11:37
From Melbourne AUS
i used a combination of reset springs (2") and 1.5" lowering blocks to achieve this look...
wanted to do it without blocks.. but it wasnt low enough after resetting springs..
dattodevils method may be worth a shot..
good luck
Posted on: 2005/8/8 11:46
1973 B110 A12
From penrith,sydney,aus
this is my ute using 2in blocks but im missing one of the leafs too.
Posted on: 2005/8/8 12:34
