Browsing this Thread:
1 Anonymous Users
help, fuel lines for 1200 |
From sydney, australia
just wanna know if i need to run bigger fuel lines for a 1200 with a ca18det in it.
I dont wanna get 600bhp out of it. Keeping it fairly standard. May just front intercool of i have money.
I suspect not but just wanna hear some point of views.
wheers
Posted on: 2005/8/14 15:58
Re: help, fuel lines for 1200 |
Quite a regular
From orange nsw
I just finished fitting 5/16 inch supply and return lines to my ca powered ute im building. should be plenty big enough for the job.
Posted on: 2005/8/25 12:24
Dont let fear hold you back!
From Warwick, QLD
yeah I orignally went with 5/16" for the feed line to the fuel rail via the fual reg, and just used the standard 1200 fual line as a return. But I got knocked back for having copper fuel lines so I went with 3/8" metal fual line, cheap as only $350 for 6 meters then you just bend it to shape, which isn't as easy as it sounds.
Cheers damo
Posted on: 2005/8/25 12:29
Drive It Like You Stole It Every Car Has 500hp In The Wet Team NEW SKOOL
From Sydney, Australia
yep, 5/16th (EFI diameter) lines are required.
I'd run a feed and return line both in 5/16th. This will mean you'll have to empty, wash and "air" the fuel tank for several days for safety before soldering in bigger line from the tank.
Explosions aren't fun, so be careful.
Posted on: 2005/8/25 12:31
'71 Green 1200 Sedan CA18DET Project 99.98% complete '71 White 1200 Sedan 20,000mi + A14T (twin 40DCOE 30/70 cam, extractors) Website: http://www.shoeys.com
$350 for fuel line? OMG.
I paid about $30 for steel bundy tube to do mine. It comes rolled up. You used to be able to buy it in straight lengths.
Posted on: 2005/8/25 12:33
Quite a regular
From orange nsw
I left the tank standard and installed a surge tank cause i didnt want to mess around with my fuel tank. i have seen a few explode before!
Posted on: 2005/8/25 12:39
thanks guys,
i thought $350 was a bit over priced.
$30 sounds good.
Is that for return lines also. I suppose it is.
i should post up some progress pics of my coupe.
it will hopefully be finished body an engine work by christmas.
Im hoping to get it drivable before i take it to body shop so as to make sure all fabrication stuff is complete.
should be a matter of weeks
I cant wait. This should go like a rocket.
Posted on: 2005/8/25 15:30
From Warburton vic
Another trick to solder your fuel tank is to connect it to an exhaust the corbon monoxidewont let it explode
Posted on: 2005/8/26 2:53
From Canberra
I went with the bundy tubes as well :) 5/16 I think. From my understanding the fuel soaks into the seams of the fuel tank and that is what will cause the explosion, even if properly drained and ventilated. I intend to take my tank to a Radiator place (had some work done through them in the past) to have the top soldered onto my UTE tank. (In-tank Bosch 040 pump)
Sorry to hijack the tread but I was wondering what people have used to hold the fuel lines in place under the car (run along the chassis Rail). I intend to run 2x 5/16 fuel lines and the rear brake line next to each other and was looking for a clamp/multiple clamps to hold them in place??
Posted on: 2005/8/26 4:15
From Warwick, QLD
yeah sorry fellas it was only $35 for my fuel lines, I must have been a little tired when I wrote that.
Posted on: 2005/8/26 10:39
