« 1 (2) 3 »
Re: catch cans- why?
From sydney
i wonder will water gets in and make my valve rust?
cause i live in a humid and hot country
You will be fine your valves are made of stainless they wont rust.
There is more water vapour going out of your engine than will be going in the breather hose.
Posted on: 2005/9/8 5:20
Re: catch cans - why?
From Canberra
Its milky coloured ....
Could be H2O condensation mixing with any condensed oil vapours, then it would be milky coloured. Clean everything up then keep a close eye on just how much your engine is breathing when hot and H2O condensation build up when cold. Maybe a leak down test done by someone you can trust to do it properly could find the source of the problem, if there is a problem.
Posted on: 2005/9/8 5:25
From Newscastle, Australia
Engine seems to be perfect I'll just keep running it until she needs a freshen....
Posted on: 2005/9/8 6:20
Dont die wondering.....
From Taupo New Zealand
Posted on: 2005/9/8 7:47
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
I wouldn't be too concerned about that.
Ona race car that is only started occasionally there is bound to be a lot more condensation under the rocker cover than in a daily driven car. And after 60 hard laps I don't think 30mL is enough to worry about. Just my 2c. How much faster are you going after a day's practice???? Thats'd what I'd be concerned with!
Posted on: 2005/9/8 7:48
1970 1200 coupe A15
1978 B310 SR16VE
From The Dat Cave.
sam1741 wrote:
hi all
currently my breather hose just
a hose leading to the ground.
If this is a road car, then just be carefull that the local motorcycle club doesn't find out who you are or they may just come around & jamb that breather pipe up your ignorant a*se. Oil spilled on the road surface is not the motorcyclists best friend, particularly in light rain & they have as much right to be safe on the road as you do.
Get a catch can & use it or restore the PCV.
Posted on: 2005/9/8 12:00
From campbelltown (sydney) australia
i wouldnt be worried so much about bikies but the authorities, i got defected for this amongst over things, and u can cop a maximum fine of 22000 dollars, i only got 200 fine but if u try take it to court ull cop it.
just wondering if anyone has had a car engineered with a catch can im just wanna know before i go trying to get it engineered with one and they wont let me.
Posted on: 2005/9/8 12:20
* caution, sunglasses must be worn to view my ca18det *
They will want to see it vented just like A14force described " vented back into the air cleaner "
Posted on: 2005/9/8 12:26
From brisbane
Don't vent it onto the road! Atleast use an old plastic Coke bottle or some other cheap/free container mounted in the engine bay to collect the oil. It'll cost you stuff all both in terms of dollars and time and is the right thing to do.
Posted on: 2005/9/8 13:24
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Brisbane, Australia
I agree with not venting to the road but some cars came that way standard, eg early holdens. They had a tube shaped like a walking stick that came out the top of the tappet cover. I wonder if that would pass current ADR's
Posted on: 2005/9/8 13:45
« 1 (2) 3 »
