« 1 2 (3) 4 5 »
Re: HELP lose flywheel
From NSW South Coast
ok it looks like I will dowel it now should I or should I not use locktite and where should I use it, I've tried it on everything before but last time I did't use any as I realised that I could get more load on the bolts if I used the oil supplied by ARP (Molly). Would it be better to use studs and nuts instead of bolts.
olboy
Posted on: 2005/9/26 9:34
From sydney australia
ross balancers at blacktown here in sydney quoted be approximately $500 for a custom harmonic balancer to suit an a series.just one question,has your crank been knife-edged?this could be the cause of the original problem,but the end of the crank was probably damaged &
will keep throwing flywheels.have you tried other cranks in the engine?i also have never dropped a flywheel,with no harmonic balancer,
but i have a full weight crank.maybe someone can lend you a crank to see if it cures the problem.if i were going to dowel the crank,i'd try & get 6 small dowels & get the crank & flywheel drilled to suit.leaving two flywheel bolts out so you can add two dowels seems like a backwards step.
Posted on: 2005/9/26 11:42
So just how big should the dowels be and how many should I use I thought I would just drill one or two 5mm holes between two bolts, maybe the bolt heads would even cover the dowel and keep it in.
olboy
Posted on: 2005/9/26 22:06
From Sydney
I will be using three dowels 120 degrees apart.
Benny
Posted on: 2005/9/26 23:22
From Sydney , NSW
b310gx,
a little misunderstanding here - I still use 6 bolts. 4 off have clearance holes at the flywheel like normal, but two (180deg apart) have holes with no tolerance so they locate the flywheel AND clamp along with the other four. Only reason I didn't dowell is the serious lack of room on the crank A larger face and therefore greater PCD for flywheel bolts would be a big improvement. Lets not forget though, when these motors were designed they were not really imagining 8 - 10000 rpm . Amazing little motors when you thing about the abuse we give them
Cheers
Posted on: 2005/9/27 0:12
From Warburton vic
My flywheel is dowled in 2 places with 5-6mm dowles. As i said before I have never had any problems
Posted on: 2005/9/27 1:02
From Taupo New Zealand
Interesting thread.... I'm going to make sure I don't miss a gear!
When these flywheels come loose, do they shear all the bolts or do the bolts just loosen? Because if they are shearing, I can't see loctite helping. Also if you use loctite you can't use oil on the threads, and if the torque settings are given with oil as the lube, if you do they up with loctite you won't get the same tension in the bolt for a given torque setting. Overtightening is playing fire because you could reach the yield strength of the bolt- then you're in the ####e for sure.
Having the two fitted bolts like R-fast said sounds like a good idea, but I think if the bolts are shearing, extra dowels would be even better as they are sharing the shear load out a bit more, reducing the load on each bolt.
Posted on: 2005/9/27 7:49
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
they break if you try to drive with it lose but this time I stopped it early enough and no damage was done. The biggest problem is that I'm flat changing and when you change up at 7500 rpm get nuetral and your foot is still on the floor who knows what revs it does
Olboy
Posted on: 2005/9/27 9:23
The problem revolves around the fact that the holes in the flywheel are 'clearance' holes & the flywheel is prevented from moving through sheer brute force & ignorance. This is just fine in a stocker that rarely sees 5.000 rpm.
However,...... it would seem that at very high engine speeds, harmonic forces in the crankshaft can be great enough to cause the flywheel to move under the heads of the bolts. Basicly, it moves around the crank just a tiny little bit, within the constraints of the amount of clearance in the bolt holes. It doesn't take much of this to fret wherever the flywheel touches something, like the crank itself, as well as under the heads of the bolts. This quickly reduces the tension, or clamping force of the bolts & allows even more movement. If left to its own devices, the holes elongate, allowing the flywheel a good runup at the bolts untill they eventually shear off.
Using tightly fitting dowls removes the job of preventing flywheel rotation [around the crank] from these bolts in clearance holes.
It's a bit like birds & airplanes. Birds use wings for motive force as well as flight. Airplanes separate these functions & use wings for flight & engines for propulsion.
Dowels do the same job of separating tasks.
The bolts hold the flywheel on, while the dowels prevent any movement.
This method works, & works well, however it addresses the SYMPTOMS, & not the CAUSE. The harmonic balancer addresses the cause.
Posted on: 2005/9/27 11:35
Love your Datsun.
Treat it well.
There is more than one way to skin a cat. I know the cause is still there but it fixes the problem so is that not good enough.
I guess a harmonic balancer and dowling would be the way to go but I'm beginning to think I should have went the cheaper CA18 way.
Olboy
Posted on: 2005/9/27 11:49
« 1 2 (3) 4 5 »
