Fuel injection set up for sale (picture up,thanks Boof)
From sydney
Posted on: 2005/11/5 3:11
Re: Fuel injection set up for sale
From Gold Coast, Australia
how much? whats included? some details please.
Posted on: 2005/11/5 5:56
From sydney
Quad 50mm throttle bodies,custom A series manifold, fuel rail ,injectors, Motec all ready to bolt on and drive away.
You will have to get yourself a high pressure fuel pump.
This is off a 200HP race motor so it is not really designed for a street motor ,but perfect for race use.
The price is $2000.
Posted on: 2005/11/5 7:53
Posted on: 2005/11/7 9:47
From Tamworth, NSW
will it need retuning on a new engine? i have an a15 so it should bolt up?
Posted on: 2005/11/7 12:44
From sydney
It came off a bored out A15 and worked fine then, so it should be a bolt on and drive away scenario.
Posted on: 2005/11/7 20:51
Isnt this converted's old Injection out of the coupe?
Good luck with the sale anywho..
Posted on: 2005/11/8 7:26
From sydney
Its off John Taylors engine (the pic), which used to be in the coupe before it was sold to Craig.
Posted on: 2005/11/8 10:06
From Newscastle, Australia
This is an awsome kit for an A series...I bought it with the hope of getting John Taylors engine, but couldnt pry it out of him. I was going to put it on mine but have since sold the A series gear and traded for the SR.
The SR has custom EFI Hardware and will have an ECU setup which will have launch, traction and data logging, but is well over double the price of this setup. (maybe triple if I go a motec!!)
I really needed the 2 litres to be able to compete with the other 2 litre lads.
This is a good price...
I believe you can use this for the street by simply retuning the Motec and also choking the 50mm bodies down to 46mm using 2mm gauge 50mm O/D alloy tubing.
Posted on: 2005/11/8 12:05
Dont die wondering.....
From Perth
I'd love it for my A15
But seems someone cut down my money tree while I was at work
Good luck with sale...... if you still got it in 6 mths let me know
Posted on: 2005/11/8 13:07
